Carbotech compounds? #1652737
07/30/14 01:33 AM
07/30/14 01:33 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Anyone use Carbotech brake pads on our non ABS and heavy cars?
I have gotten a couple of different recommendations like XP12 front/ XP10 or XP8 rear.
Just wanted to see what other people use here.
Not interested in any other brand just Carbotech feedback please
Thanks!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Carbotech compounds? [Re: RylisPro] #1652738
07/30/14 01:48 AM
07/30/14 01:48 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
I have CT627A XP8 (rear) and CT731 XP12 (front) on the Valiant, so far they work VERY well! Car is roughly 3200lbs
Re: Carbotech compounds? [Re: ScottSmith_Harms] #1652739
07/30/14 01:49 AM
07/30/14 01:49 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
2
Re: Carbotech compounds? [Re: ScottSmith_Harms] #1652740
07/30/14 02:13 PM
07/30/14 02:13 PM
Long Island, NY USA
BergmanAutoCraft Offline
Long Island, NY USA
I run 8s and 10s. Not cheap but work very well.
Re: Carbotech compounds? [Re: BergmanAutoCraft] #1652741
07/30/14 02:48 PM
07/30/14 02:48 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Hey Peter which do you run in the fronts? XP10's?
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Carbotech compounds? [Re: RylisPro] #1652742
07/31/14 08:48 AM
07/31/14 08:48 AM
Long Island, NY USA
Long Island, NY USA
Yes 10s are for the front.
Re: Carbotech compounds? [Re: RylisPro] #1652743
09/06/14 05:13 PM
09/06/14 05:13 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
I was able to install my front Carbotech pads yesterday. If you have Dr. Diff's Stage 4 Brembo style caliper brake kit the part number is CT968 and whatever compound you choose. I have XP12's in front and to install them you have to have zero shims whatsoever. They are a tight fit but as long as you are able to move the wheel back and forth freely you should be good.
The the rear CT627A-XP8's I was not able to install on Dr. Diff's Cobra Rear brake kit. The pads I was sent are simply too thick even with the piston fully collapsed and zero shims on the back of the pads. I am emailing Carbotech at the moment and will call them Monday for a solution.
Initial impressions from driving 30 miles and back on a freeway: they eat up rotors big time. I had street pads on previously and you could still see the cross hatching from when the rotors were brand new after about 1200 miles. The Carbotechs ate through that and now has its own distinct wear pattern after 60 miles. I have not properly bedded them yet and will do so before my track day on Sept. 20th.
Oh yeah they are loud when crawling to a stop. Be prepared to get looks from people on the street haha!
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Carbotech compounds? [Re: RylisPro] #1652744
09/06/14 06:04 PM
09/06/14 06:04 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
It looks like I will need the thinner CT627 pad for 2000 Cobra R's instead of the thicker CT627A pad for 94-04 Cobras.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Carbotech compounds? [Re: RylisPro] #1652745
09/07/14 10:40 PM
09/07/14 10:40 PM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
Sounds like they sent you '94-'04 Mustang GT (thick) rear pads.
You need '94-'04 Cobra (thin) rear pads. Cobra R's use this same rear caliper/pad.
BTW, I'm still waiting for your slotted front rotors to arrive. The mfg sent me the drilled/slotted version by mistake.
Re: Carbotech compounds? [Re: RylisPro] #1652746
09/07/14 10:51 PM
09/07/14 10:51 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
This is good to note...
Re: Carbotech compounds? [Re: DoctorDiff] #1652747
09/07/14 11:01 PM
09/07/14 11:01 PM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Thanks Cass yeah I'm gonna need those rotors.
It still amazes me that people still want drilled rotors that just crack faster at the track.
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Carbotech compounds? [Re: RylisPro] #1652748
09/08/14 12:47 AM
09/08/14 12:47 AM
Lethbridge, AB, Canada
dangina Offline
dangina  Offline
I never had a cracked drilled rotor ever
Re: Carbotech compounds? [Re: RylisPro] #1652749
09/13/14 08:11 AM
09/13/14 08:11 AM
NorCal
RylisPro Offline OP
RylisPro  Offline OP
NorCal
Yeah the CT627 pads work perfect with the Dr. Diff rear brakes. They are a bit cheaper than CT627A's also
I just have to say that engineers who designed the brake pads for these Ford Cobra rear brakes never tried to install it themselves
what a pain
73 `Cuda
YouTube: RylisPro
www.rylispro.com
925-214-9192
