Which intake would you use? #1652218
07/28/14 10:57 PM
07/28/14 10:57 PM
Utah
dragnduster Offline OP
Utah
I just got my 512 low deck short block and am trying to figure out which intake to use with it. This will be a race only motor and I would like to use my 1050 alky dominator on it. I will be using my standard port Victor heads from my 440 on the stroker and they have had extensive porting done to them. I will use a roller cam that is 268/276@.050 and .630/.650 lift. The car it will be going into weighs 3230 with me in it, will have a glide with 5600rpm (approx) converter and 4.86 gears with 14/33 inch slicks.
If this was your car what intake manifold would you run?
Re: Which intake would you use? [Re: dragnduster] #1652219
07/29/14 12:02 AM
07/29/14 12:02 AM
AndyF Offline
AndyF  Offline
Standard port, low deck, 4500 carb = Mopar Performance M1 4500. As far as I know that is the only std port 4500 intake available.
Indy has a low deck but it is MW ports. Edelbrock makes a 383 Victor but that is a 4150 flange. The Super Victor is RB only.
Re: Which intake would you use? [Re: dragnduster] #1652220
07/29/14 12:18 AM
07/29/14 12:18 AM
You have a PM
Re: Which intake would you use? [Re: Cab_Burge] #1652221
07/29/14 12:30 AM
07/29/14 12:30 AM
Utah
Utah
Thanks Andy and Cab for your thoughts. Cab you have a PM
