Restoration Shop Needed In California #1651304
07/26/14 07:03 PM
07/26/14 07:03 PM
Central Coast, Calif.
Snoopy Offline OP
Snoopy  Offline OP
Can anyone recommend a Mopar restoration shop on the Central Coast of California? I have decided to have someone else finish the restoration on my 70 Cuda and need to find a shop that can do the job without any drama and do it right the first time.
Thanks for any help.
Re: Restoration Shop Needed In California [Re: Snoopy] #1651305
07/26/14 09:23 PM
07/26/14 09:23 PM
West Central Wisconsin
DeMopuar Offline
DeMopuar  Offline
I wouldn't sweat just California. There's a guy I'm using in Wausau, Wisconsin that is awesome at sheet metal work. He's a small shop, and does all of the work himself, and can do whatever kind of detail you want to see. He can do the original spot weld look, or he can just plug weld everything too depending on your budget. He's even saved the spot welds on one side of sheet metal that he can save, and he does this by grinding off the opposite side spot weld while leaving the one side that you want to save. He doesn't have to go to that route if that's not what you're looking for, but he does have that kind of skill -- which no shop that I am aware can even do anymore. The spot weld "artwork" I've seen shops do now looks like the end of a 1/2" to 3/8" drill bit end -- looks bad to me; but hey, to each their own I guess.
This guy does more than just metal work too. He understands how these cars go together and does assembly work as well. If you're looking for high quality, I can recommend this guy.
If you would like more information just PM me and I can give you the guys' contact information. I know he's busy, which is a good thing, but damn, if it were me and I had the money, I'd definitely get in line if the distance thing doesn't scare you.
Best of luck with whatever way you plan on going.
Mark
Re: Restoration Shop Needed In California [Re: Snoopy] #1651306
07/27/14 06:44 AM
07/27/14 06:44 AM
P
PasiR Offline
PasiR  Offline
P
Re: Restoration Shop Needed In California [Re: PasiR] #1651307
07/27/14 11:24 AM
07/27/14 11:24 AM
Ball Ground GA
TrueTripleX Offline
TrueTripleX  Offline
Ball Ground GA
Julius.
http://www.rbyj.com/
X2 I have worked with Julius for yearly 15 years and have had GREAT experience with his quality, and knowledge of Mopars (especially B and bodies). And he won't take a year to do the work. Give him a call (Tuesdays thru Saturdays)
Re: Restoration Shop Needed In California [Re: TrueTripleX] #1651308
07/28/14 11:00 AM
07/28/14 11:00 AM
Reno, Nevada
NV69B7RR Offline
NV69B7RR  Offline
Reno, Nevada
Another vote for Julius. He has been doing mopar restos since the 80's and has very solid reputation.
Re: Restoration Shop Needed In California [Re: NV69B7RR] #1651309
07/29/14 04:30 PM
07/29/14 04:30 PM
Snoopy Offline OP
Snoopy  Offline OP
Thanks for the leads. I will have to pass on Julius, he is not what I am looking for at this time. I am looking for someone closer because the car is all apart at this time and transport would be hassle and from experience, I need to be close enough to check on progress.
