Thanks for the pics. I assume that when base/clear is used on the top, a single stage is used for the overspray affect? I think that's how Mike Ross did his pink T/A.
How are the inner sides of the front frame rails done? They will get painted with the engine compartment but at the same time, they fade out towards the torsion bar x-member. Some clear coat will get on the dip primer won't it? Won't that give an unwanted affect?
I'll also look into the RestoRick paint. Thanks for the link.
