Mini alternator question #1650417
07/24/14 12:10 PM
07/24/14 12:10 PM
Madison Wi
NTOLERANCE Offline OP
Madison Wi
Picked this up for free. Came of a a running industrial engine that was newer had about 500 hours on it.
45 amp or so. Gm 3.0 liter. 2011
Any thoughts on how to wire it in? I believe it's internally regulated
Re: Mini alternator question [Re: NTOLERANCE] #1650418
07/24/14 12:12 PM
07/24/14 12:12 PM
Madison Wi
Madison Wi
Label
Re: Mini alternator question [Re: NTOLERANCE] #1650419
07/24/14 12:18 PM
07/24/14 12:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I see 4 terminals, that means it"s externally regulated?
And 45A is kinda wimpy nowadays isn't it?
Re: Mini alternator question [Re: jcc] #1650420
07/24/14 12:58 PM
07/24/14 12:58 PM
Madison Wi
Madison Wi
Yeah maybe it is wimpy. Who knows. Worth a shot
Edit. Tag says 70 amps
Re: Mini alternator question [Re: NTOLERANCE] #1650421
07/24/14 01:10 PM
07/24/14 01:10 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It says right on the tag 70A..the hook up would be
the bat is your output, the 2 little wires are the
field wires(they go to the regulator and one to a
keyed hot)
the other single would be a volt meter.. here is a
simple wiring diagram for it lacking the volt meter
wire
Re: Mini alternator question [Re: MR_P_BODY] #1650422
07/24/14 01:14 PM
07/24/14 01:14 PM
Madison Wi
Madison Wi
Thanks Mr P. Looks like a near bolt in
I think i have the plug for it as well.
Re: Mini alternator question [Re: NTOLERANCE] #1650423
07/24/14 01:21 PM
07/24/14 01:21 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Make sure the case has a good ground... I've seen many
of the industrial ones that have a separate plug
for the volt meters.. basically only on the industrial stuff
Re: Mini alternator question [Re: MR_P_BODY] #1650424
09/23/14 12:53 AM
09/23/14 12:53 AM
Madison Wi
Madison Wi
I actually got around to fitting this today
Couple of spacers and a couple of washers
Fits well even though the batt terminal is buried
True test will be when the engine is running to see if it vibrates at all.
Those are oem brsckets
