8 3/4 chunk with no number?? #1650012
07/23/14 10:21 AM
07/23/14 10:21 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I was rummaging thru my gear sets last night thinking about a gear change for the Dart.
I have a 3.91 open chunk that has no number on it. (489-741-742)
I was told they were the older units and were typical to the 742 cases. Anyone have any info?
I'm going to roll a clutch posi unit into it and want to make sure it doesn't have the small diameter pinion.
The Dart has slicks and the 340 makes decent power, I don't want to waste time with something that might break.
...FAFO...
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650013
07/23/14 11:22 AM
07/23/14 11:22 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
I was expecting a picture of the chuck , not the car ...
Are there any numbers or letters at all on the chuck anywhere?
The smallest part of the pinion is where the outer pinion bearing slides on , behind the yoke. The 741 and the 489 use the same bearing, 742 is the same size too, same bearing ??? ... anyway if you are worried about the pinion breaking you'll strip the teeth off the ring and/or pinion before you break the pinion stem itself.
Re: 8 3/4 chunk with no number?? [Re: JohnRR] #1650014
07/23/14 11:44 AM
07/23/14 11:44 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I will get a pic of the front of the chunk tonight. Reason I ask is that a bunch of years back I snapped a 741 off clean behind the yoke on the pinion shaft. I don't want that to happen again...
...FAFO...
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650015
07/23/14 11:56 AM
07/23/14 11:56 AM
I twisted the splines on a 741 pinion in the stock car (mild 360/class rules) & no drag race standing starts . I only saw it when I went to pull the yoke off later on. Maybe it was a one time deal but it kinda made me leery of em for a high powered app
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650016
07/23/14 12:52 PM
07/23/14 12:52 PM
The only time I've seen a pinion gear broke like that was from a 4 wheeldrive offroad racer, he had the driveshaft to pinion gear angle all goofy I've drag raced the snout out of a 741 with 3.91 gears in my 1969 Dart GTS with a 440 and a 727 on slicks, it is tougher than the stock 489 chunks as far as I'm concerned
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650017
07/23/14 04:00 PM
07/23/14 04:00 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
That spot can break on all the 8.75's because they are all the same size there.
Re: 8 3/4 chunk with no number?? [Re: JohnRR] #1650018
07/24/14 11:42 AM
07/24/14 11:42 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Low and behold after digging thru what was a pretty good build-up of rust I found a line of small numbers. For whatever reason the numbering sequence and placement is entirely different than the other 5 I was comparing it to. Looks like its a 489 case. Plan on rolling an early clutch pak unit in and changing the yoke. The one that's on there is in pretty bad shape. Counted the pinion and ring gear teeth and confirmed it is a 3.91.
...FAFO...
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650019
07/24/14 11:58 AM
07/24/14 11:58 AM
Nashville, TN
MOPARMIKE69 Offline
MOPARMIKE69  Offline
Nashville, TN
Looks like a really early unit
69 Road Runner vert
69 GTX hard top
70 Road Runner 4 speed
70 Hemi Cuda vert
Re: 8 3/4 chunk with no number?? [Re: MOPARMIKE69] #1650020
07/24/14 12:00 PM
07/24/14 12:00 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
I didn't know if the smaller stamp below the others was a date stamp or not but it looks like it says 1963???
...FAFO...
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650021
07/24/14 02:09 PM
07/24/14 02:09 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
What is the big leter or number cast above the pinion on the drivers side of the chunk itself.
Factory gears I have looked at will have at minimum the ring and pinion tooth counts and/or the gear ratio along wit hthe date the gears were made.
489s wouldn't have been made in 1963 , it might be 1968 and it won't be coded with 4 digits for the year.
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650022
07/24/14 04:02 PM
07/24/14 04:02 PM
Make sure you read and understand the instructions on how to properly change the pinion yoke on the "489" case third members (IE pinion shaft crush sleeve preload) If you do not know how or have the proper tools to do that correctly take it to a shop that does
Re: 8 3/4 chunk with no number?? [Re: Cab_Burge] #1650023
07/24/14 04:21 PM
07/24/14 04:21 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
John, I will check what the letter is this evening.
Cab, I have been spoiled on this. When I was dirt racing with a 9" the builder always set it up with a crush sleeve, then removed it and replaced it with the correct shims. Yoke changes were simple and painless. Guess I'm back to having to be careful again. I have done it in the past but may need to read up on it again as a refresher course.
...FAFO...
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650024
07/24/14 05:02 PM
07/24/14 05:02 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
the problem with the 489 is you can't pull the crush sleeve out from the yoke end , you have to pull the carrier and the pinion to change it .
2 reasons why 489's are the least desirable , the cone type sure grip and the crush sleeve .....
Re: 8 3/4 chunk with no number?? [Re: JohnRR] #1650025
07/24/14 05:22 PM
07/24/14 05:22 PM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
John I have another set of 3.91's I took out of my Satellite. They are set up with the good posi unit in a 741 case with the correct yoke. When I had them in my car they had a growl when off the throttle (coast). I thought maybe using the 489 set may be the lesser of two evils? He11 for all I know the 489's may growl. Either way I have enough of a parts selection to develop a back-up plan...
...FAFO...
Re: 8 3/4 chunk with no number?? [Re: JohnRR] #1650026
07/25/14 12:36 AM
07/25/14 12:36 AM
Kansas
BEINGmeISaCRIME Offline
Kansas
Thank goodness they came up with the solid spacer for the 489 cases. Cone style sure grip =
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650027
07/25/14 03:57 AM
07/25/14 03:57 AM
Polson, MT
DoctorDiff Offline
DoctorDiff  Offline
Polson, MT
That is a '72-'74 casting.
Re: 8 3/4 chunk with no number?? [Re: DoctorDiff] #1650028
07/25/14 09:23 AM
07/25/14 09:23 AM
Western Md.
skicker Offline OP
"The Champ"
skicker  Offline OP
"The Champ"
Western Md.
Ding Ding Ding
Cass is right. I found a date on the ring gear last night. After checking the case for condition I remembered where this set came from.
These were removed from a 74 Snow Commando p/u that was nearly rusted in half. Took them out thinking there would be a posi unit there and instead ended up with the 3.91 open rear. The date on the ringear is 6/25/73.
I looked over the 741 case 3.91's as well last night.
Something I found that was interesting was the part # stamping on both sets of 3.91 gears in two different number cases.(741-489) was the same.
2070228 391-1 MS 291
Date on the ring gear in the 489 set was 6/25/73.
Date on the ring gear in the 741 set was 6/28/70.
Just thought it was strange...
...FAFO...
Re: 8 3/4 chunk with no number?? [Re: skicker] #1650029
07/25/14 03:30 PM
07/25/14 03:30 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Ding Ding Ding
Ring gears don't care what size the pinion stem is , the ring and pinion tooth count is still the same so both rears having the same part number is not strange.
