indy maxx block pushrod oiling
#1649968
07/23/14 03:44 AM
07/23/14 03:44 AM
Posts: 268 ca
brownout
ca
many of you have probably seen my other post on spray bar oiling. This is how to pushrod oil with an indy block.
indy maxx low deck block. how do I get pressurized oil to the lifters? How does indy prep these blocks for pushrod oiling? I am getting t and d individual shaft rockers for the b1 heads and I have crane 66550-16 lifters setup to oil through the pushrod. Who runs pushrod oiling with an indy block and if you do please help me out.
Thanks, Cody
Re: indy maxx block pushrod oiling
[Re: Forest]
#1649978
07/24/14 05:05 PM
07/24/14 05:05 PM
Posts: 901 oh
julian2007
oh
push rod oiling on a indy maxx block is a breeze but costly. If the block is new it think it is 250.00 to gun drill it, however if is a finished block meaning the lifter bores are finished then you need to bush them after gun drilling. On my b1 mc setup I use t&d paired rockers, Trend push rods, Comp elite lifters and best machine installed restrictors in the back of the block to control the oil.
Best machine race engines is pretty much a master of b1 heads and pushrod oiling mine work perfect I would call them
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
[Re: julian2007]
#1649979
07/24/14 05:20 PM
07/24/14 05:20 PM
Posts: 5,485 SoCal
Brian Hafliger
SoCal
When you drill the block for lifter oiling like the factory does, the lifter bores will LEAK a TON compared to how we did Forest's block...not saying it's wrong, but it makes a very big difference in leakage going from factory type oiling to a metered .060 hole!
And no chance of aerating the oil with a small hole that cannot be uncovered. Brian
Brian Hafliger
[Re: julian2007]
#1649981
07/24/14 09:42 PM
07/24/14 09:42 PM
Posts: 16,925 NC
440Jim
NC
What size are the oil restrictors in the back of the block? Some common ones I saw are 0.060".
[Re: 440Jim]
#1649983
07/25/14 10:20 AM
07/25/14 10:20 AM
Posts: 901 oh
julian2007
oh
I would have to ask Best I'll let you know Bruce
[Re: 440Jim]
#1649986
07/28/14 01:07 PM
07/28/14 01:07 PM
Posts: 16,925 NC
440Jim
NC
Thanks, it is good to know that 0.060" as a starting point is plenty of oil for the top end, and it could be restricted further based on your and BMRE experience.
[Re: 440Jim]
#1649987
07/28/14 04:14 PM
07/28/14 04:14 PM
Posts: 901 oh
julian2007
oh
I have put 200 laps on it, sent it in for a refresh and everything was happy in the valve cover area pic of old car but still have the same motor
