How do you make a factory tach work with an MSD system? #1649936
07/23/14 12:47 AM
07/23/14 12:47 AM
Tulsa, Ok
WadeMetzinger Offline OP
Tulsa, Ok
1970 Dart with factory dash tach and I'm installing an MSD system (6al, and pro billet distributor).
Can I just hook it to the tach output on the MSD 6AL box?
Wade Metzinger 918-809-0987
71 Cuda 9.28@145 -1s, Pglide
68 Cuda 10.64@124 1.45 60's 318->390 eddys
Moparts discount code on WIX - moparts www.Filter1.com
Re: How do you make a factory tach work with an MSD system? [Re: WadeMetzinger] #1649937
07/23/14 12:54 AM
07/23/14 12:54 AM
South San Francisco, Ca
70sixpkrt Offline
70sixpkrt  Offline
I have the same setup. I tried hooking my stock tack to the msd box and it still didn't work. I heard you have to run a tach adapter. I ended up using a Autometer tach.
[img]http://www.imgur.com/hxlGUJt.gif[/img]
4-speed
3:54 Dana
13.01 @107.93 with street tires (not hooking up)
Re: How do you make a factory tach work with an MSD system? [Re: WadeMetzinger] #1649938
07/23/14 12:54 AM
07/23/14 12:54 AM
IN
ahy Offline
ahy  Offline
IN
With factory tach a MSD adaptor is normally required. If you search Summit or other vendors you will find several adaptors listed... pick based on description and wire per instructions. I know on my '70 Rally tach I tried just hooking up the wires and no reading at all. With the adapter recommended it worked... sort of. Not real accurate but it worked. In my case the recommended adapter was the less expensive version.
Re: How do you make a factory tach work with an MSD system? [Re: WadeMetzinger] #1649939
07/23/14 12:57 AM
07/23/14 12:57 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
normally the trigger wire (usually green but maybe yellow on factory) that would go to the negative side of the coil goes to the tach output on 6AL. But being factory may need this tack adapter
http://chucker54.stores.yahoo.net/casehousings.html
How are you triggering the MSD MSD dizzy points mopar dizzy??
Says if you are triggering through the white wire since your using MSD dizzy I'd thing just wire to tach output??
bunch of stuff hear
http://www.msdignition.com/page.aspx?id=3300
Re: How do you make a factory tach work with an MSD system? [Re: Dodgem] #1649940
07/23/14 12:58 AM
07/23/14 12:58 AM
Ontario, Canada
Dodgem Offline
Dodgem  Offline
Ontario, Canada
Re: How do you make a factory tach work with an MSD system? [Re: WadeMetzinger] #1649941
07/23/14 01:04 AM
07/23/14 01:04 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
Since my tach was fairly slow responding, I just bought a reproduction one and sold the original for what the reproduction one cost. You could also have the electronics in the stock one replaced.
Re: How do you make a factory tach work with an MSD system? [Re: 451Mopar] #1649942
07/23/14 11:26 AM
07/23/14 11:26 AM
usa
smos001 Offline
smos001  Offline
usa
I hooked up the adapter on my MSD 6AL on my 70 challenger. The tach works now but it revs slow and it is off a bit. I did find a thread about using a capacitor in-line to adjust the tach adapter a bit.
I have not tried the capacitor yet.
If anyone has put the extra capacitor in line that has some experience with it, please tell us how it worked.
Re: How do you make a factory tach work with an MSD system? [Re: WadeMetzinger] #1649943
07/23/14 02:10 PM
07/23/14 02:10 PM
Tucson, AZ
cruzin Offline
cruzin  Offline
Tucson, AZ
I tried using the MSD adapter with a factory tach and was unsuccessful. Had my factory E-body tach rebuilt and upgraded. If you do have your factory tach gone-through, you may need to specify that you will be using a MSD type ignition system otherwise they may not set it up for this.
