Re: tie rods, b& e body
[Re: 70moparmike]
#1649759
07/22/14 06:23 PM
07/22/14 06:23 PM
RapidRobert
More info. The car is together or apart & you have some new ones & the threaded shank is longer than what came out of there or? Generally you want to screw em into the sleeve as far as they will go leaving enough threads so the sleeve can be turned to make the assy a bit shorter later when it is aligned. I'd start by getting the box halfway between it's lock to lock travel and the wheels straight ahead then screw em in till the length is just right so the tapered tie rod ends will go right in the center st link/lbj tapered holes with some threads left on each end so the assy can be shortened a bit further as needed to get the toe in dead on but more info on what's going on/where you are at
