How will drag radials on the rear affect handling? #1649548
07/22/14 01:10 AM
07/22/14 01:10 AM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
My Challenger is pretty basic,
1.06 FF t bars
Stock front sway bar
ESPO XHD leafs
KYBs at all 4 corner
Subframe connectors
Eventually I am adding some FF or Hotchkis sway bars.
I run 15 inch wheels and don't know that I will be changing them anytime soon(wheels and tires are expensive!)
I currently have 235/60 and 245/60r15s F/R on the car. BFG T/As of course.
What's going to happen handling wise if I put Nitto drag radials on the back? This is a road car. It's not an auto Xer, but I want it to handle well. I like driving it on old country roads. Not excessively fast necessarily, but I don't want to ruin my handling by throwing street slicks on the back and keeping the hard compound T/As up front.
Also, would siping the T/As help with traction?
Re: How will drag radials on the rear affect handling? [Re: FuryBoy] #1649549
07/22/14 05:03 PM
07/22/14 05:03 PM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
I guess what I wondering is will this cause a dangerous combination of understeer?
Re: How will drag radials on the rear affect handling? [Re: FuryBoy] #1649550
07/22/14 06:43 PM
07/22/14 06:43 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
Dangerous? Not necessarily. You're adding grip to the rear, not adding roll resistance to the front, so IMO your front should retain the same level of grip it had before (same weight transfer, same tire); the caveat is the rear will now have more grip, so you may be tempted to push the combo further. The change will definitely be a move in the 'more grip in rear' direction. Depending on where you currently lie (understeer/balanced/oversteer), this could be a good or a bad thing.
Does the car currently have a tendency to oversteer or understeer?
If you make the change and you find it's got too much push for your taste, then swap in a larger front Hellwig bar. Or put drag radials on the front and report back (I'd love the nitto drag radial to be a 'good' cornering tire for all 4 - you could be the guinea pig)
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: How will drag radials on the rear affect handling? [Re: Uhcoog1] #1649551
07/22/14 08:30 PM
07/22/14 08:30 PM
Eugene, OR
FuryBoy Offline OP
FuryBoy  Offline OP
Eugene, OR
Seems to have a decent amount of understeer now, but I haven't pushed it to hard in the corners...
I was thinking about M/T drag radials in the front, I think they make a 245/60r15
Re: How will drag radials on the rear affect handling? [Re: FuryBoy] #1649552
07/23/14 12:15 AM
07/23/14 12:15 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Considering that Drag radials usually have taller sidewalls, I'd wonder about lateral response. I've considered getting them for the Charger but I like tight reaction on switchbacks. I'd expect taller sidewalls to have more flex, reducing the confidence level.
Report back what you learn.
Re: How will drag radials on the rear affect handling? [Re: Kern Dog] #1649553
07/23/14 02:44 AM
07/23/14 02:44 AM
Nebraska
72Swinger Offline
72Swinger  Offline
Nebraska
Drag radials just are not designed for hard cornering. Nitto NT555II is a cornering DR or just run NT01's.
Mopar to the bone!!!
Re: How will drag radials on the rear affect handling? [Re: 72Swinger] #1649554
07/29/14 07:16 PM
07/29/14 07:16 PM
Sweet Home Alabama
MRMOPAR622 Offline
MRMOPAR622  Offline
Sweet Home Alabama
I run the Nitto NTO5 Drag Radials on my car &I'm very happy with the handling.Mine are 19" rim size so I have a shorter sidewall but if any thing is now faster as you can run 30 PSI on the street(I run 26 PSI Cold in mine)and let them down to 18 PSI if you want to race.Due to running higher air pressure unlike low pressure in a Drag Slick you will not have any problems at 80-90 MPH in curves.If you want Traction the NTO5 Drag Radial is the right choice if its only handling you want the NT555 is best.It said my picture was to big to post so I added a link hopefully for you to see I run them.
<a target="_blank" href="http://imageshack.com/f/ip64aef5j"><img src="http://imagizer.imageshack.us/v2/150x100q90/673/64aef5.jpg" border="0"></a>
"To Be The Man'You Have Got To Beat The Man" "T/D and Pro-Bracket Racer"
