ABS Light #1649363
07/21/14 07:17 PM
07/21/14 07:17 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
The brake warning/ABS light is on in my 97 Dodge 1500 4WD. I have replaced brake lines and bled everything but I can't get it to go out. Stopping power of the system seems OK. Any thoughts on what I should do to get it off?
Re: ABS Light [Re: 70VERT] #1649364
07/21/14 10:11 PM
07/21/14 10:11 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Do you have RWAL or ABS?
Re: ABS Light [Re: 70VERT] #1649365
07/21/14 11:18 PM
07/21/14 11:18 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
I'm pretty sure it doesn't have ABS, although it has the idiot light
Re: ABS Light [Re: 70VERT] #1649366
07/22/14 09:29 AM
07/22/14 09:29 AM
N
NITROUSN Offline
NITROUSN  Offline
N
Look at the front brake hoses. If there are wires attached to the hoses with plastic H clips you have abs. If no wires go to the bearings you have rwal. You need to verify that to determine what system you have to diagnose proprely.
Re: ABS Light [Re: NITROUSN] #1649367
07/22/14 12:11 PM
07/22/14 12:11 PM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
out of the blue guess from experience puts my money on the rear speed sensor mounted on top of the diff.... but as stated, need more info.
Re: ABS Light [Re: J_BODY] #1649368
07/22/14 09:11 PM
07/22/14 09:11 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
Just checked....no wires on front hoses
Re: ABS Light [Re: 70VERT] #1649369
07/23/14 01:27 AM
07/23/14 01:27 AM
N
NITROUSN Offline
NITROUSN  Offline
N
So you have RWAL. As J-Body said the sensor on the rear axle would be the least expensive and easiest to do. Make sure the wires look ok as they drop down from the frame and go to the axle mounted sensor.
Re: ABS Light [Re: NITROUSN] #1649370
07/23/14 01:35 AM
07/23/14 01:35 AM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
OK thanx. I'll give it whirl after work tomorrow
Re: ABS Light [Re: 70VERT] #1649371
07/28/14 04:33 PM
07/28/14 04:33 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
Looking things over, I'm not sure how this comes apart. Does wire connection just pull off? Also, the bracket is bolted to the axle and the Ebrake cable is attached. Does the sensor just pull out? Want to make sure before I just start yanking. It's really a rusty mess under there. Thanks
Re: ABS Light [Re: 70VERT] #1649372
07/28/14 11:53 PM
07/28/14 11:53 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The wires unplug. There will be a release tab on the connector. There will be a bolt holding the sensor into the housing. Blow it off and spray around the sensor to loosen the rust. The sensor may be tight. Twist it back and forth as you lift on it with pliers or channel locks.
Re: ABS Light [Re: NITROUSN] #1649373
07/31/14 07:41 PM
07/31/14 07:41 PM
PA--USA
70VERT Offline OP
70VERT  Offline OP
PA--USA
Disconnected the sensor and the light went out. Also followed the advice given and got it out OK.
Replacement sensor is like 52 bucks. What happens if I just leave it disconnected? I don't notice any difference without it right now
