Changing rear tyre diameter / height #1648811
07/20/14 07:46 PM
07/20/14 07:46 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
Currently run a 275/60R15 Hoosier (radial)28" tall
What would I see if I went to a 30x9 (radial) measure at 29.5" .I have 8" rims .
I know the rear effective ratio will change slightly .
I presume the 60' will drop and the MPH should pick up . Possibly help a little with traction , bigger footprint .
Any other things to think of ?
Car is a 68 Satellite , I will have to check a 30x9 will fit without touching the dogleg .
Weight on Saturday was 3657lbs with me in it , and I am a pretty skinny son of a gun
I have had traction issues the last 2 rounds , it has been low 50's/40'sF cold. I dropped 2psi and softened rear shock 1 click on Saturday had 2 spins and 1 turn of the tyres .
thanks for all the help
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Changing rear tyre diameter / height [Re: tex013] #1648812
07/22/14 01:54 AM
07/22/14 01:54 AM
western Ky
CraigS Offline
CraigS  Offline
western Ky
For what its worth I went from a 28 x 10 slick to 29.5 x 10.5 slick and it did not change either 60 fts,mph or et,or even consistency for that matter.Really ,no change at all.
Re: Changing rear tyre diameter / height [Re: CraigS] #1648813
07/22/14 02:25 AM
07/22/14 02:25 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Tex I run the 30 x 9 Hoosier radial slick and I like them. I am actually running them on a 7" steelie now as when I had them on the 8" wheel they would rub up inside the 1/4 when I hit bumps with a passenger in the car. They were to far out as my 7" wheels moved the wheel in some and it fits centered in my stock wheelwell now. It really depends on your combo if you will see any change. I am running 4.30's with them and they seem to work good with the 4.30's. The car hooks good with the 7" wheels as the last time out on them it pulled a 1.50 sixty which is my best and ran 10.76 three passes in a row. The car hooked good all day on them tires on the 7" wheel. These are the 7" wheels in this pic. Ron
Re: Changing rear tyre diameter / height [Re: 383man] #1648814
07/22/14 07:38 PM
07/22/14 07:38 PM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks or the replies
I guess it is try it to find out .
Ron you know I like your car , I ran a 1.51 on the only none turn run , 1.53 with a turn in eliminations - 10.965@115 on the brakes for a DQ oh well
Tex
New best MPH 130.32
Re: Changing rear tyre diameter / height [Re: tex013] #1648815
07/22/14 09:43 PM
07/22/14 09:43 PM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Ron you know I like your car , I ran a 1.51 on the only none turn run , 1.53 with a turn in eliminations - [Email]10.965@115[/Email] on the brakes for a DQ oh well
Tex
Are you using Cal Tracs as I forgot ? Ron
Re: Changing rear tyre diameter / height [Re: 383man] #1648816
07/23/14 12:38 AM
07/23/14 12:38 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
yes Ron,
Caltracs with Mopar XHD springs
Tex
New best MPH 130.32
Re: Changing rear tyre diameter / height [Re: tex013] #1648817
07/23/14 01:24 AM
07/23/14 01:24 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
Thats a good 60 for your car Tex. Ron
Re: Changing rear tyre diameter / height [Re: 383man] #1648818
07/23/14 04:52 AM
07/23/14 04:52 AM
Sydney,Australia
tex013 Offline OP
tex013  Offline OP
Sydney,Australia
thanks Ron,
I do try to set my cars to 60 as fast as possible - can make up for a little less power
10.70's -- I need some more ci's
Tex
New best MPH 130.32
