Currently run a 275/60R15 Hoosier (radial)28" tall
What would I see if I went to a 30x9 (radial) measure at 29.5" .I have 8" rims .
I know the rear effective ratio will change slightly .
I presume the 60' will drop and the MPH should pick up . Possibly help a little with traction , bigger footprint .
Any other things to think of ?
Car is a 68 Satellite , I will have to check a 30x9 will fit without touching the dogleg .
Weight on Saturday was 3657lbs with me in it , and I am a pretty skinny son of a gun
I have had traction issues the last 2 rounds , it has been low 50's/40'sF cold. I dropped 2psi and softened rear shock 1 click on Saturday had 2 spins and 1 turn of the tyres .
thanks for all the help
Tex
