Re: How to make 1200-1300 streetable HP?
[Re: Airwoofer]
#1648617
08/12/14 03:41 PM
08/12/14 03:41 PM
Posts: 5,763 Hot Rod Ridge
FastmOp
Hot Rod Ridge
Call Procharger! There tech is great. They invented the sh!t ![](/ubbthreads/images/graemlins/devil.gif)
[Re: Airwoofer]
#1648618
08/12/14 04:18 PM
08/12/14 04:18 PM
Posts: 2,646 Plymouth Meeting, PA
bigtimeauto
Trophy Winner
Trophy Winner
I am pretty much leaning toward a procharger for the 499. It has the block, crank (Bryant A fuel with 2 1/4" slots), and heads and is 4.470 bore and under 4" stroke. I don't think a crank gear driven unit is a good maych for the car but a side mount may work. Where can I get details about mounting the unit, the pulleys and also accessory drive for the vac pump and the alt? Needs to be compatible with a Jesel cam drive, ATI balancer (will get the keyway slots), motor plate, Indy reverse flow and elec water pump. The driver side of the front of the motor is wide open except for the stock oil filter location (but a big pump and cover).
What does the blower mount on?
What would be a good manifold and how much carb? Now there is a tall single plane w/ Dominator and lotsa NOS plumbing. The B1 heads are on a short deck KB block.
Big Time is a distributor for Procharger and has a proven car. I will be using him when I am ready. It will cut down on the learning curve which can be very expensive.
Why? He won't answer messages. Strange cause I am wanting a F2 on my BB and have the dough. Is this a Moparts thing or just me? Is the process to just drop off your car many states away and just wait to be told to come and get it when they are done and here is the bill?
I just check my machine and there is no messages back to work I go
BB, TT5,Procharged 3300lb Street Car 4.79/154
[Re: bigtimeauto]
#1648620
08/13/14 11:53 AM
08/13/14 11:53 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
I have both combos, I ran a f-2 cog side slinger for the last 5 years making 24lbs no issues. now I have the gear driven chris alston drive.
Dude awesome car, so awesome I see Fred in the back ground checking it out ![](/ubbthreads/images/graemlins/laugh2.gif)
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
