Re: 2 questions I have on timing
[Re: 75dusted]
#1647949
07/18/14 04:53 PM
07/18/14 04:53 PM
RapidRobert
pull the DR front (#1) plug & crank it carefully in bursts at the starter relay till you feel pressure coming up on your thumb on the plug hole. Bump it a bit more at the SR or with a 1&1/4" socket/breaker bar turn it further CW till the timing marks are at 15 BTDC. Set the dist housing so the magnet is dead even with the tooth that places the rotor pointing at or close to the #1 plug wire. See if it will start & holler back. check that the plug wires are in order 1-8-4-3-6-5-7-2 CCW on a BB and CW on a SB. EDIT If it's off enough that you have to reclock it I would suggest keeping the wires in the OE location (where #1 is for standardization which is forward and slightly to the pass side) and reclocking the intergear wherever it needs to be to achieve that. MORE EDIT I reread & what was the issue that you pulled the dist for and did it run before you pulled it?
[Re: RapidRobert]
#1647950
07/18/14 05:48 PM
07/18/14 05:48 PM
Posts: 21,083 Niles , Ohio
therocks
Niles , Ohio
To check chain stretch.Set the damper on zero by hand turning the crank with a socket.Pull the cap and see how much the crank turns on the timing tab compared to the rotor moving.IIRC no more than 8 or 10 degrees .After that its chain time.As said you probally have the dist in 180 out.Pull it and turn it 180.Rocky
Chrysler Firepower
[Re: 75dusted]
#1647953
07/18/14 10:53 PM
07/18/14 10:53 PM
RapidRobert
Before pulling the dist I would (1) set the timing marks on 15 BTDC making sure I am on #1 compression and see which cap terminal the rotor is at then (2) if the rotor at that point is on #1 I would with a 1&1/4" socket/breaker bar move the crank back or forth slightly as needed till the tooth is dead even with the magnet (best is to be coming forward "clockwise" at that point which takes the slack out of the chain) & holler what timing you have on the dampener at that position. Holler with what you see. (3) if it is on #6 then no need to do (2), just set the marks to 15 (#1 compression)/flip rotor/dist 180 to get back on #1/line up the tooth to the magnet with rotor pointing to or close to #1. (& if it ain't real close note that vac adv will shift rotor phasing CW on a big block. See if it will fire. What was the problem with the other dist other than the clamp being loose? EDIT Phasing-CCW on a SB
