5.7 hemi swap 1987 ramcharger #1647394
07/16/14 10:09 PM
07/16/14 10:09 PM
iowa
dairyfarmer Offline OP
iowa
Tackling a project this summer and looking for help Started with a really clean 87 Ramcharger 360/727. Have a 5.7 from an 06 ram. I want to keep the 727. I have purchased an Auto Hot Wire harness, an 05 hemi ecm, an 03 hemi bellcrank. Looking for advice, parts sources, tech info on the overall project, specifically engine tranny matchup, exhaust (headers?), air conditioning, fuel, cooling, power steering. appreciate any advice and will gladly supply pictures and reports as the project advances
Re: 5.7 hemi swap 1987 ramcharger [Re: dairyfarmer] #1647395
07/16/14 10:13 PM
07/16/14 10:13 PM
Garden Grove, CA
OzHemi Offline
Penguin-hating Ginger
OzHemi  Offline
Garden Grove, CA
You'll want to post this in the truck section of the forum..
https://board.moparts.org/ubbthreads/postlist.php?Cat=0&Board=Warlock
Re: 5.7 hemi swap 1987 ramcharger [Re: dairyfarmer] #1647396
07/16/14 11:04 PM
07/16/14 11:04 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
There is a user (JesseR) selling a 5.7 out of an 82, hopefully he find this post and can chime in on some useful tips. ad is here
From what I know I think you will need to fabricate the engine mounts, a small block 727 will bolt onto the new hemi with just a new flexplate available from mopar. I imagine any rad that will cool a BB will cool a 5.7. headers will most likely be shorty truck units. These are all just guesses though
Re: 5.7 hemi swap 1987 ramcharger [Re: dairyfarmer] #1647397
07/16/14 11:45 PM
07/16/14 11:45 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 5.7 hemi swap 1987 ramcharger [Re: 3hundred] #1647398
07/17/14 12:24 AM
07/17/14 12:24 AM
iowa
iowa
Thank you, the links were very informative. Looks like I might have to contact the S & P folks. Tom
Re: 5.7 hemi swap 1987 ramcharger [Re: dairyfarmer] #1647399
07/17/14 07:15 PM
07/17/14 07:15 PM
St.Clair Shores, Mich
bryansgarage Offline
So how do you make the speedometer work without the rear axle sender? I put a 96 Van 318 fuel injected motor in my 88 Ramcharger and that problem still stumps me. I wanted the O.D. trans ,maybe that's the problem.
Re: 5.7 hemi swap 1987 ramcharger [Re: bryansgarage] #1647400
07/17/14 07:27 PM
07/17/14 07:27 PM
Canada
CTD5.9 Offline
CTD5.9  Offline
Canada
looks like they used a Dakota Digital SGI-5 speedometer signal interface, probably feeds off the transmission and then requires you to swap in an electronic speedometer.
