340 Stumbles after hard throttle
#1647167
07/16/14 06:49 AM
07/16/14 06:49 AM
Posts: 885 alberta
Publicbottle
alberta
After 13+ yrs restoring my challenger I ve been out driving it over the past two weekends! Feels great and I have fewer bugs to work out than I expected!
One problem I am hoping to get some help with is tuning my Holley 5150 600 dp.
My experience fiddling with carbs is limited, however this is something I would like to become better at. So here's the issue...
As I shift into gear (first->second or second->third) and heavy on the throttle, the car pulls fine but as I let off the pedal and coast, car stumbles and sometimes it dies sometimes i can save it by feathering the gas. If car does die, it starts up again with out much issue, then i can continue driving ok, but i can reproduce the problem almost everytime.
Some more details.... Exhaust smell burns the nose, lean/rich? I took a plug off after idling in the garage and it looked fine to me, maybe a bit lean. Ive checked the float levels and they were ok, ive hooked up a vacuum gauge and adjust the 2 idle mixture screws for MAX vacuum ( 14-15 is as high as i got), adj the idle screw so it idles ok about 800-900rpm. Car runs pretty cool (180-190) although its been hot here recently.
The car: 70 Challenger, 4speed OD, 3.73 rear, elect ignition.
The Engine: 69 340, bored .030 MoPar M1 dual plane intake holley 600cfm 2.02 valves CAM advertised dur 268/276 lift .429/.444
Ive found some help on the Holley website, but was hoping to get some more direction from the experienced folks on moparts!! Any ideas where to go next
Re: 340 Stumbles after hard throttle
[Re: Publicbottle]
#1647168
07/16/14 11:52 AM
07/16/14 11:52 AM
RapidRobert
You might take out the idle mix screws & shoot a 3 second blast of starting fluid into each port but it does idle OK at rest. The unburned fuel can be too rich or too lean (lean misfire & you smell the fuel that is there at the tailpipe which ain't being burned). What's your initial timing. Reluctor gap OK. rotor phasing OK. fuel level at bottom of sight holes. floats not hanging up or waterlogged. Kind of WAG here but wanted to toss out some thoughts. It acts up coming back to idle when you let off the gas but it idles OK at rest which does point a bit toward the carb. holler with any news
[Re: Paul_Fancsali]
#1647170
07/17/14 02:09 AM
07/17/14 02:09 AM
Posts: 10,559 Freeport IL USA
poorboy
Freeport IL USA
Back in the old days, there used to be a device that set between the throttle and the throttle stop (I believe it was called a dash pod? been a long time), That device simply cushioned the throttle from slamming close when you left off the gas pedal. This was used because when we went from wide open, to instantly letting off, the throttle plates would effectively close off all the incoming air into the motor creating a momentary fuel over load from the fuel that was flowing into the intake and through the carb. Since the fuel weighs more then the air, it takes longer to get it moving, but it also takes a little longer for it to quit moving. The dash pod would hold the throttle blades open just long enough to allow the fuel to stop moving before the air was completely stopped.
If the problem your experiencing is the motor dieing when you abruptly let of the gas after running wide open, this could solve your issue.
As far as the burning of the eyes from gas fumes at an idle, its likely a cause of the cam. High lift, long duration with a big valve open overlap are not real efficient at idle. Its the nature of the beast. Gene
[Re: poorboy]
#1647171
07/17/14 01:17 PM
07/17/14 01:17 PM
Posts: 18,582 Rust Belt, SW PA
Silver70
Rust Belt, SW PA
I had the same issue with a 413, I pulled the holley, put on an edelbrock 600 and the problem went away. Also fixed the very rich exhaust smell. I even tried 2 other holleys before making the switch... the engine just liked the edelbrock I guess.
68 Road Runner, 69 Belvedere, 71 Challenger Vert 340 barracuda, 01 Ram CTD, 95 Ram, 04 Ram, 85 Daytona turbo Z 66 GTO, 06 Magnum RT AWD. 07 Ram CTD, 07 Ram
[Re: ademon]
#1647176
07/18/14 04:17 AM
07/18/14 04:17 AM
Posts: 885 alberta
Publicbottle
alberta
Ya this is a 4spd car. I will start with the simplest and easiest solution first....bumping up the curb idle to 1000rpm and see if I can duplicate the problem... I am swamped busy for a couple days here, but I promise to report back. Thanks for the ideas this far everyone!
[Re: floridian]
#1647179
07/31/14 02:30 AM
07/31/14 02:30 AM
Posts: 885 alberta
Publicbottle
alberta
Float level....................
what too low? i have it just at the bottom of the sight hole
[Re: Publicbottle]
#1647180
07/31/14 09:40 AM
07/31/14 09:40 AM
Posts: 1,574 Lakeland FL
floridian
Lakeland FL
Too high.. Fuel is sloshing forward on deceleration. Try lowering the level... You can always raise it up again??
