Belt drive fuel pump mount pics #1647016
07/15/14 05:43 PM
07/15/14 05:43 PM
Minnesota
RockChip Offline OP
RockChip  Offline OP
Minnesota
I'm looking for some pics and ideas to mount a belt drive fuel pump setup on a big block.
Finally found some time to work on my junk.
Re: Belt drive fuel pump mount pics [Re: RockChip] #1647017
07/15/14 09:50 PM
07/15/14 09:50 PM
Plymouth Meeting, PA
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
fuel pump is in the trunk
BB, TT5,Procharged 3300lb Street Car 4.79/154
Re: Belt drive fuel pump mount pics [Re: bigtimeauto] #1647018
07/15/14 10:11 PM
07/15/14 10:11 PM
Las Vegas
afxcoronet Offline
afxcoronet  Offline
Las Vegas
Here you go.
Taking over the World one win light at a time.
Re: Belt drive fuel pump mount pics [Re: afxcoronet] #1647019
07/19/14 12:24 AM
07/19/14 12:24 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Big time can you show a closer pic of the pump mounting and plumbing.
Re: Belt drive fuel pump mount pics [Re: FastmOp] #1647020
07/19/14 01:53 AM
07/19/14 01:53 AM
Sherwood park, Alberta.
go green Offline
go green  Offline
If you have a Jesel belt drive just spin it of the cam with no belt at all .
6.50 @ 226 MPH 4.25 @ 186 MPH
https://www.youtube.com/watch?v=YX86DHGKBo0
Re: Belt drive fuel pump mount pics [Re: FastmOp] #1647021
07/19/14 04:37 PM
07/19/14 04:37 PM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
pump is in the trunk:
Re: Belt drive fuel pump mount pics [Re: bigtimeauto] #1647022
07/19/14 04:53 PM
07/19/14 04:53 PM
Upstate NY
Bigcube Offline
Bigcube  Offline
Upstate NY
Is that cable driven? (like a speedo cable?)
On the motor pic, which is the belt drive unit for the fuel pump? I didn't know such a thing existed
Re: Belt drive fuel pump mount pics [Re: bigtimeauto] #1647023
07/19/14 04:58 PM
07/19/14 04:58 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Did you plug both hi speed lean outs?
I picked up this same setup from Waterman. I'm mounting it today and hopeing to get the cable ordered Monday.
I was wondering about the cable and how it would bend as well. Yours looks like it is pretty flexible.
I needed to lower my Amp draw and my Magnafuel would not keep up so this was how I solved both issues.
Re: Belt drive fuel pump mount pics [Re: Bigcube] #1647024
07/20/14 12:56 AM
07/20/14 12:56 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
Yes the pump is cable driven. The cable in this pic is from waterman and can drive up to a 9 gallon per minute pump. The red aluminum part on the right side of the picture is the drive part. I needed it out of the way of my headers and oil pump.
Re: Belt drive fuel pump mount pics [Re: FastmOp] #1647025
07/20/14 12:58 AM
07/20/14 12:58 AM
bigtimeauto Offline
Trophy Winner
bigtimeauto  Offline
Trophy Winner
I run a carb so there is no need to bleed fuel off out of the pump. Try to run the cable with the least amount of bends and you will have no issues.
