Torque Specs: 440 source Rods and mains? #164636
12/09/08 02:18 AM
12/09/08 02:18 AM
808CUDA Offline OP
808CUDA  Offline OP
Just curious to see what everyone here has used for torque specs on a 500" 440 source kit based on a 440 RB.
I have these specs from the Service Manual:
-Rod bolts: 45 ft lbs
-Main Bearing Caps: 85 ft lbs.
Thanks for the input in advance!
Re: Torque Specs: 440 source Rods and mains? [Re: 808CUDA] #164637
12/09/08 02:47 AM
12/09/08 02:47 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Don't use those specs..they are for smaller lower grade bolts, 440 Source uses 7/16 ARP SP2000 bolts, the stock bolt is 3/8, I/m on the road & my sheet is at home so I won't quote a # but it's alot higher then what you've got there...
Re: Torque Specs: 440 source Rods and mains? [Re: 808CUDA] #164638
12/09/08 02:48 AM
12/09/08 02:48 AM
SO. CAL.
70blackfish Offline
70blackfish  Offline
SO. CAL.
I think the rod is 75lbs and 80lbs main
but dont quote me
Re: Torque Specs: 440 source Rods and mains? [Re: 70blackfish] #164639
12/09/08 02:51 AM
12/09/08 02:51 AM
808CUDA Offline OP
808CUDA  Offline OP
Thanks guys for the input.
Randy, Can you post up the torque specs when you get a chance? Thanks
Re: Torque Specs: 440 source Rods and mains? [Re: 808CUDA] #164640
12/09/08 02:55 AM
12/09/08 02:55 AM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I'll be home saturday... Are you using ARP main bolts or studs? FWIW 75 sounds right for the rods but again I don't have the spec in front of me...85 is stock bolts, pretty sure ARP studs are higher...
Re: Torque Specs: 440 source Rods and mains? [Re: 1_WILD_RT] #164641
12/09/08 03:03 AM
12/09/08 03:03 AM
808CUDA Offline OP
808CUDA  Offline OP
Randy, ARP main bolts. So 85 for mains sounds right?
I am going to aski Kim at 440 source, but wanted to ask addt'l opinions from the pros
Re: Torque Specs: 440 source Rods and mains? [Re: 808CUDA] #164642
12/10/08 01:29 AM
12/10/08 01:29 AM
Re: Torque Specs: 440 source Rods and mains? #164643
12/10/08 02:08 AM
12/10/08 02:08 AM
808CUDA Offline OP
808CUDA  Offline OP
cudabob, thanks for the link. I have those specs , but I can only use the main cap specs. The rod bolts are ARP and require a higher torque spec.
I e-mailed Kim @ 440 source and he was kind enough to call me early today.
He gave me the torque specs:
ARP Main Bolts (not studs): 85 ft lbs
ARP2000 Rod bolts: 75 ft lbs
ARP 8740 Rod bolts: 60 ft lbs
Re: Torque Specs: 440 source Rods and mains? [Re: 808CUDA] #164644
12/10/08 11:50 AM
12/10/08 11:50 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
My belief has always been:
The correct torque (and lube) to use on the mains is to duplicate whatever was used when the block was align honed.
The correct torque (and lube) to use on the rods is to duplicate whatever was used when the rods were resized (or if not resized, then initially machined.
Rich H.
Esse Quam Videri
