Hydraulic brake issues; pedal to the floor
#1646099
07/13/14 07:40 PM
07/13/14 07:40 PM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Hey gang..... As they say, nothing worth a hill-of-beans comes easy. I got the hemi running this weekend.. BUT, I have a brake issues..... I have a brand new Hemi-Booster/master cylinder assemble, all new lines, rebuilt calipers, new proportioning and safety valve. I have been bled the master cylinder and the complete system. I have done a round-trip twice and as far as I see, the air bubbles are gone. There are NO leaks anywhere. But, the pedal goes all the way to the floor and if I pump it a few times, I'll get some forward brakes. I friend of mine suggest that the problem could be a non-centered situation with the piston assembly inside the safety valve. I mentioned I, as my son is putting pressure on the pedal, loosen the input fitting from each of the reservoirs, one at a time and let it bleed. He stated I should hear or feel a pop of the piston assembly centering itself ( there are springs on the top and bottom side of the piston assembly. Anyone done this before? I get plenty of fluid when I bleed the brakes, it is just that I gain no pressure...
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: Hydraulic brake issues; pedal to the floor
[Re: hemi68charger]
#1646100
07/13/14 07:48 PM
07/13/14 07:48 PM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
At the shop we had problems with Fords mostly recentering the PP valve.We would open a frt bleeder as someone mashed the pedal.It usually centered it.Rocky
Chrysler Firepower
[Re: therocks]
#1646101
07/13/14 08:25 PM
07/13/14 08:25 PM
hemi68charger
Houston, Tx
Wow,, Sounds just like my friend's fix. So, tomorrow, I'll position my line wrench on the input line coming FROM the master cylinder and loosen it as he presses down. Once he's on the floor, then I'll tighten it. Then, I'll repeat for the next master cylinder reservoir input line into the valve. Hopefully, that'll fix it....
[Re: stumpy]
#1646103
07/13/14 09:22 PM
07/13/14 09:22 PM
hemi68charger
Houston, Tx
At the wheel not the master.
At the wheel? Whatcha talkin' about Willis?
[Re: hemi68charger]
#1646104
07/13/14 09:42 PM
07/13/14 09:42 PM
RapidRobert
(1) bad M/C (even tho new)(2) air somewhere. On a tough case I plug the MC with 2 inverted flare male cap plugs from the Edelman cabinet at your parts house & cap the MC ports & if the MC is good and bled out the pedal will be rock hard with virtually no travel. then hookup either line & work on that half then the other half when it is taken care of
[Re: RapidRobert]
#1646105
07/13/14 09:56 PM
07/13/14 09:56 PM
Posts: 8,668 Buford, GA
I_bleed_MOPAR
Buford, GA
Dumb question time- you did install the calipers with the bleeder screw on top? Ran into that several times over the years. Tim
'71 Charger 383/727 '17 Challenger SXT (Wifeys car )
[Re: RapidRobert]
#1646106
07/13/14 10:00 PM
07/13/14 10:00 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
air somewhere.
Gets my vote...
[Re: stumpy]
#1646107
07/13/14 10:16 PM
07/13/14 10:16 PM
therocks
Niles , Ohio
Stumpy is right at the frt wheel bleeder.Sometimes it takes more than one try.If not Id say a bad master or air in the line.The bleeders on the calipers are facing up I hope?When I did the disc conversion on the 65 I went thru a gallon of fluid.Then I saw the frt bleeders were down and not up.Dumb mistake even after doing brakes for 30 years.Rocky
Chrysler Firepower
[Re: therocks]
#1646108
07/13/14 11:10 PM
07/13/14 11:10 PM
Posts: 5,357 Rancho Cordova, California (Sa...
hemi71x
I just read, and responded to your other posting, about bleeder secrews.
You have your caliper hard lines, and or, bleeder screw, installed improperly.
RF-4C Phantom 69-370 Zweibrucken, Germany
[Re: hemi71x]
#1646109
07/14/14 01:31 AM
07/14/14 01:31 AM
hemi68charger
Houston, Tx
JV, Per my response on the bleeder screws, I'll be addressing this fubar tomorrow after work.......
Thanks everyone...
[Re: DAYCLONA]
#1646111
07/15/14 01:16 PM
07/15/14 01:16 PM
hemi68charger
Houston, Tx
last night I swapped the transition tubes and bleeder screws on the calipers to the appropriate side. After bleeding the front again, I regained a stiff pedal, doesn't go all the way to the floor any more. But, the rears still don't stop when I'm going through the gears on jack stands. So, I'm going to crack open the input tubes into the safety valve coming from the master cylinder one at a time ( in hopes of centering the piston assembly inside - if they aren't centered and causing poor movement of the rear wheel cylinders. After I bleed the saefty valve, I'll crack open the input tube to the proportioning valve down the framerail while Jacob pushes the pedal to the floor ( tighten the fitting once pedal is all the way down ). Then, I'll bleed the rears again. Hopefully I'll regain the stopping capability of the rears. The shoes are adjusted..
Mike, I haven't separated the MC from the booster. But, since Wayne(theramman) made it for me, I'm confident it is correct.
[Re: hemi68charger]
#1646112
07/15/14 01:42 PM
07/15/14 01:42 PM
RapidRobert
put a block of wood under the brake pedal so the cups ain't gonna be pushed beyond their normal travel range. I would highly suggest you split the MC/booster & check/confirm nub clearance. The brake warning light being on is an electrical warning that tells a driver that one side has failed (low psi) & the light itself/centered position of the valve itself is unrelated to the rear half not being right (assuming the offending half of the system is now sealed, it just tells a driver that one side was or still does have a leak causing low psi. When you get the system squared away you can recenter the light so it's off
[Re: RapidRobert]
#1646113
07/15/14 03:29 PM
07/15/14 03:29 PM
hemi68charger
Houston, Tx
.... When you get the system squared away you can recenter the light so it's off
Thanks for the reply. The warning light only came on when I drove the car up and down the driveway Sunday ( pedal would go to the floor ). But now, with the air out of the calipers (ie, the bleeder in the proper upper position), the light doesn't come on any more. The pedal is definitely firm now.. But, when you really push down, the rears don't stop ( car is on jack stands ). When I am running the engine/tranny, the motor is pulling about 11 inches Hg.
[Re: hemi68charger]
#1646115
07/15/14 09:54 PM
07/15/14 09:54 PM
RapidRobert
There is still a blockage/issue somewhere as the rears should definitely be locking up (usually they lock up too fast). EDIT or there is still some air in there even tho it dont feel like it
[Re: stumpy]
#1646116
07/15/14 10:34 PM
07/15/14 10:34 PM
Posts: 4,945 WI
Dcuda69
WI
You could try stomping on the brake pedal because that does work some times. I don't think bleeding the lines going into the proportioning valve will help. You need to bleed the lines coming out of it. Also try readjusting the rear brakes they may be a bit loose.
Open a frt bleeder and have your helper hit the pedal hard all the way to the floor! You will probably hear/feel a thud in the pedal. Close the bleeder and then slowly pump the pedal. Hopefully that will get the pressure to the rears back where it should be.
[Re: Dcuda69]
#1646117
07/16/14 11:07 AM
07/16/14 11:07 AM
hemi68charger
Houston, Tx
Hello All, I put the bleeder and transition tubes for the calipers in the proper order. I had the bleeder screws on the bottom location instead of the top. Sooooo, I bleed the front calipers and now I have a nice hard pedal, but too hard now and the rears STILL BARELY move, yet I can bleed the rears (fluid comes out). Maybe there isn't enough pressure. I cracked up the input lines from the master cylinder into the safety valve and had Jacob press the pedal, fluid came out of both. Of course, I did them one at a time and he didn't lift until I tightened the line. Sooooooo, I'm sort of back to square one. I will begin with the master cylinder next. I'll take my bleeder tubes I made out of unused MC tubes for which I have them bend so they terminate within the appropriate reservoir. I will press the pedal and see if I have movement. If I do, then I'll go onto the safety valve one line at a time. This will be a pain in the-you-know-what since everything is in the engine compartment. There's not much else that could be restricting the flow/pressure of the fluid to the rear. Steady as I go, one step at a time.....
I don't think my rod-to-MC clearance is an issue. There doesn't seem to be "unreleased" pressure at the corners. I can rotate the front rotors alright.
[Re: hemi68charger]
#1646118
07/16/14 11:35 AM
07/16/14 11:35 AM
Posts: 18,157 Mass
DAYCLONA
Mass
Won't/Don't know until you check it... if the stoke isn't long enough, the rears may not see full pressure
