biggest stock 318 cam possible? #1645847
07/13/14 12:39 AM
07/13/14 12:39 AM
Pa. U.S.A.
moparborn Offline OP
Pa. U.S.A.
What is the biggest cam that will go in a stock piston ,302 (188/160 valve)head 1988 318 engine without any clearance issues?
Re: biggest stock 318 cam possible? [Re: moparborn] #1645848
07/13/14 01:23 AM
07/13/14 01:23 AM
Philadelphia
radar Offline
radar  Offline
Philadelphia
I think you might run into coil bind and or valve float before you smack a piston with a valve. It's hard to get a lot more lift without some duration to get the ramps to not be tok fast/steep. So before you even run out of mechanical clearance you'd possibly start dealing with cams that need lots of rpm to be happy and not have enough spring pressure to control them. There is a reason everybody checks it with clay though- tolerances can stack up against you and the piston to valve contact might not be at TDC. Also you'd need more static compression to make up for compression loss from intake/exhaust overlap with a 'big' cam.
People seem to like the 268 or whiplash cams for stockish builds.
Re: biggest stock 318 cam possible? [Re: radar] #1645849
07/13/14 03:46 AM
07/13/14 03:46 AM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
Most 318 cams had .373 lift. Pretty meager! The 1968 manual trans 340 cam was in the neighborhood of .458 lift if I recall and they had almost 2 points higher compression.
Re: biggest stock 318 cam possible? [Re: moparborn] #1645850
07/13/14 12:14 PM
07/13/14 12:14 PM
scratchnfotraction Offline
I have run a lunati VooDoo roller cam in my 91/302 headed 318 and now have the Hughes whiplash roller cam.
it has .485/.485 lift with no issues. I run it with comp 901-16 springs. all stock retainers/rockers/PRs/roller lifters.
if it has the exhaust rotators on the exhust side you have to ditch those. they will not take much lift and have coil bind as the spring is shorter.
I recommend the whiplash roller in a stock 318 engine, choppy idle,smoooths out around 1800 rpm and is a very nice street cam for a daily driver. woke it right up as far as HP/performance.
IIRC .500 lift will need valve guides cut for that much lift/coil bind needs measured for sure.
the LA/magnum head don't like much over the .485 lift in stock forum.
Re: biggest stock 318 cam possible? [Re: scratchnfotraction] #1645851
07/13/14 02:22 PM
07/13/14 02:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We ran Summits cam in at least 3 SB 318s.Never had a problem and they ran good.It really made a difference in my old Ram Charger with 200K on it.Rocky
Chrysler Firepower
Re: biggest stock 318 cam possible? [Re: therocks] #1645852
07/14/14 04:15 PM
07/14/14 04:15 PM
dogdays Offline
dogdays  Offline
302 heads run the smaller valves, 1.78, 1.5. Unless you put larger valves in them, that's what would be in a 302 head.
The '88 pistons are flattops and are 0.055" down in the hole. I think you can run 0.474 lift but as said above, you will definitely have to cut the valve guides for clearance and get the right springs.
R.
Re: biggest stock 318 cam possible? [Re: dogdays] #1645853
07/19/14 01:48 AM
07/19/14 01:48 AM
Pa. U.S.A.
Pa. U.S.A.
Thanks for the replies.
The heads had 1.88/160 valves installed and appear to had the guides cut down and viton seals installed when I got them,I did some pocket work and port matched them,installed comp 901-16 springs.
I already have a comp 480/480 cam.
Will be using .025 head gaskets.
I will drop some playdough down to check clearances to be sure.
