Cams, solid lifter or hydraulic???
#1645406
07/11/14 06:09 PM
07/11/14 06:09 PM
Posts: 10,132 A Red State
SNK-EYZ
A Red State
I'm planning on a cam upgrade in the 572 Hemi in my car and I'm trying to decide whether to stay with a hydraulic cam or go to a solid lifter cam. The one in the engine now is a M/Perf 524/292 hydraulic cam and it's just flat above 4800. The engine will never see higher than 6500 rpm. At the end of the quarter mile it's at 6200-6300. The car is mainly a street car that will get raced some. The cams I've been looking at on both (solid and hydraulic) are roughly 600 lift roughly 250 duration at .050 lift. Hughes Hydraulic cam Howards Hydraulic cam One of the solids is a NEW MOPAR PERFORMANCE SOLID LIFTER CAMSHAFT FOR A 426 HEMI ENGINE.PT NO P4529345. THIS IS IN NEW CONDITION AND READY TO INSTALL. SPECS ARE 312 DEGS DURATION LIFTS ARE .614"/.598" I've tried searching on here and mostly what I read is it's mainly a personal preference for the most part. What are the pros and cons of solid vs hydraulic other than the obvious of lifter adjustment?
Re: Cams, solid lifter or hydraulic???
[Re: JohnRR]
#1645408
07/11/14 07:29 PM
07/11/14 07:29 PM
SNK-EYZ
A Red State
Most of the guys I've talked to don't like the short valve spring life of a roller cam because of the high spring pressures. I don't want to have to replace valve springs every year or two. The high price on the roller cam stuff kinda deters me also. I'm not trying to get maximum power out of it. It's a street car first and a race car second. There's always someone faster and being a poor retired guy I can't afford to compete $$$$ wise. I guess I'm trying to figure out if a hydraulic cam will perform decently up to 6500 rpms. A few HP isn't going to make any real difference to me for racing. As long as it pulls decent in the 5000-6500 range. If The solid is my better choice in that range I guess I'll go that route. I race to have fun, if I win great. I'm not going to lose any sleep if another car is faster than mine.
[Re: SNK-EYZ]
#1645412
07/11/14 09:57 PM
07/11/14 09:57 PM
Posts: 16,925 NC
440Jim
NC
I'm planning on a cam upgrade in the 572 Hemi in my car and I'm trying to decide whether to stay with a hydraulic cam or go to a solid lifter cam. . . . What are the pros and cons of solid vs hydraulic other than the obvious of lifter adjustment?
If you are never going over 5900 rpm, a hydraulic is fine.
What are the flow numbers of your Hemi heads? What is the torque converter stall speed?
A 572 cubic inch engine will eat duration for breakfest, so depending on CR, duration is your friend.
[Re: RUNCHARGER]
#1645414
07/11/14 10:36 PM
07/11/14 10:36 PM
SNK-EYZ
A Red State
The car has a 4.10 Dana in it, the trans is a reverse pattern manual with a Dynamic 9.5 inch convertor that supposed to stall between 3600-3800 (seems to do that).
At the end of the quarter mile it's usually revved to 6200 roughly.
I don't plan on revving it past that but I want to make sure that the power curve is still pulling to at least that.
The shift light is set at 5700 for now but it needs more cam to even pull to that rpm.
[Re: RUNCHARGER]
#1645415
07/12/14 12:32 AM
07/12/14 12:32 AM
Posts: 6,392 nielsville, minn.
quickd100
nielsville, minn.
I don't think I would spin a street 572 to 6500 but that's just me I guess. That MP camshaft in the 528, do you remember the RPM range? I'm screwing my 528 together now with a little 560 lift solid and I'm already considering going a bit bigger. I'd be happy to shift it around 5500 but it has to make steam too.
Sheldon
You'll have to wait until at least Tuesday for me to look over any notes. I'm 250 miles south this weekend for my grandson's baptism.Dave
[Re: SNK-EYZ]
#1645423
07/13/14 04:24 PM
07/13/14 04:24 PM
Posts: 984 Tennessee
Hemi ragtop
Tennessee
My dyno test w/246I and 254E on 112LC just under .600 lift with lash solid roller on 540ci HEMI Horsepower topped out @ 5,900 rpm, sounds like you need to be in the 260 degree area to pull 6,200 rpm in a 572
