Re: How long for lifters,springs,rockers?
[Re: fattire]
#1644434
07/09/14 09:17 AM
07/09/14 09:17 AM
Posts: 52,972 Romeo MI
MR_P_BODY
This is the fourth season on my solid roller set up,limited street use and 4-6 times to the track.It's a Scott Brown cam mid 650's lift Comp lifters and Harland rockers, when should I think about having them rebuilt or replaced?
Pull and spring and check it but I would think you should get a few more years depending on the ramps and spring pressure
[Re: fattire]
#1644435
07/09/14 09:29 AM
07/09/14 09:29 AM
Posts: 10,011 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I go by the lash changes. If you see a change of more than .003, better find out why. You should probably check it often now. Like Mike said, it depends on ramp rates and how well the valvetrain has been controlled by the springs. It wouldn't hurt to check spring pressures on the weakest ones, if you have the tools. I have a Manley tool that goes over the rocker arms and uses a torque wrench to check pressures. It can't give you a perfect number of pounds, but will show if they are all close or if there is a weak one.
[Re: gregsdart]
#1644436
07/09/14 12:48 PM
07/09/14 12:48 PM
Triple Threat
Renton Washington
I currently have 335 1/4 Mile passes on my Springs and lifters. Rockers have more than that. Valve Springs still check good and lash hasn't moved so I haven't bothered to change anything. It will come apart for a freshen up this winter.
Cam is 278/284 .619/.641 Comp Lifters Comp Springs T&D rockers
[Re: fattire]
#1644439
07/09/14 02:25 PM
07/09/14 02:25 PM
Posts: 4,209 New York
polyspheric
New York
Not science, but... Rotate the rocker and tappet wheels over with your fingers. If: you can rock the wheel sideways at all, or if there is a tight spot, or any up-&-down play, or it feels crunchy..
it's toast.
Boffin Emeritus
