Re: Which 72-93 truck should I buy?
[Re: torredcuda]
#1644266
07/10/14 04:13 PM
07/10/14 04:13 PM
Posts: 5,302 CA, Proprietor; The "PALOMINO"...
dynotune440
So which years have the fulltime 4wd, I see the `77 military trucks have it?
Full-Time 4WD NP203 Transfer Case rigs.... 1975-1979 all dodge truck models 100-400 1974-1979 ramcharger and trailduster
1972-74 trucks used NP205 gear driven t-case which was remotely mounted(divorced), and front axles used drum brakes
1980-1993...100 thru 300 with the Dana 44 front axle used the Aluminum NP208 or NP241 transfer case, and in 1985 went to CAD axle 1980-1993 200 and 300 series with the Dana 60 Front axle used the NP205 transfer case.
All 1975-1993 had Disc Brakes
Dinuba, California, Home of the PALOMINO ranch and 440 truck farm, where dodge trucks have a home. Have Four 1979 dodge PALOMINO trucks now.
[Re: Soopernaut]
#1644268
07/11/14 03:31 PM
07/11/14 03:31 PM
Posts: 8,064 Iowa
76dodgeboy
Iowa
Is an 80-84 front disc brake axle a bolt in for a 72-74 truck? I suppose you may have to swap master cylinders.
As long as gear ratio is the same. They bolt in a little diff but will swap. You can also swap just the knuckles out from any 80-93 and install it on the 72-74 axle
[Re: RODHALL]
#1644271
07/17/14 08:38 AM
07/17/14 08:38 AM
Posts: 12,494 Western Colorado High Desert
moparmarks
88-93 would be my perfered years... here is why 1 88 start of the Cummins... 2 fuel injection on gas trucks. 3 NP241 on gas trucks NP205 on Cummins and 1 ton trucks... Body parts exchange on 81-93 trucks Less the 91-3 rad supports... 5 727 88 / A518 89up trans Cheep if needed rebuilds 6 Dana 60 fronts on CTD and most 1 tons... must have np205 gear drive transfer... 7 full door panels and headliners and trim, on most upgraded models.. * fuse box that don't melt or catch fire like on 76-80 trucks... 9 Not full time4x4... 72-80 trucks...
I think I hit most of it...
The heater fan and the running lights fuses both melted in my 92 along with the ignition and headlight switches. Several problems Dodge never fixed for 22 years.
72 Satellite Sebring Plus 440, 72 Dart 5.9 4-spd, 68 Valiant, 73 W200, 78 D100 sb, 78 D200, 98 DAKOTA, . Moparmarks Parts & Restorations Desert Mopar Metal Grand Jct. CO 970-261-7039 http://moparmark.com/motormangj@gmail.com
[Re: 76dodgeboy]
#1644273
07/17/14 08:50 AM
07/17/14 08:50 AM
moparmarks
Chevy disc is a real conversation on the 72-74 4x4. 72-74 D100 had disc.
