ladderbars/4 links #1642996
07/06/14 09:49 PM
07/06/14 09:49 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
For the guys that running these suspensions is it common for these locknuts on these helms to get loose? Is it something I should be concern with?
Re: ladderbars/4 links [Re: racerx] #1642997
07/06/14 10:22 PM
07/06/14 10:22 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I've had mine come loose from time to time.
Doug
Re: ladderbars/4 links [Re: racerx] #1642998
07/06/14 10:24 PM
07/06/14 10:24 PM
They will come loose, check and tighten them regularly
Re: ladderbars/4 links [Re: racerx] #1642999
07/06/14 10:33 PM
07/06/14 10:33 PM
MR_P_BODY Offline
MR_P_BODY  Offline
If your shocking the bars then yes they can get loose..
also the type of heim will matter.. if you use the
solid heim on the front of a ladder bar you shouldnt
tighten them real tight or they bind the heim and they
need to be checked often
Re: ladderbars/4 links [Re: MR_P_BODY] #1643000
07/06/14 11:52 PM
07/06/14 11:52 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs Gents one more ? What do uall use to lube the heims with...............Thaxs
Re: ladderbars/4 links [Re: racerx] #1643001
07/07/14 11:53 AM
07/07/14 11:53 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I have a spray can of a dry lube(I dont remember the
name) but it doesnt attract the dirt and stuff.. I
clean them with brake clean and blow dry them then
spray them with the dry lube... I have used WD-40
when I couldnt find the dry lube
Re: ladderbars/4 links [Re: MR_P_BODY] #1643002
07/07/14 08:22 PM
07/07/14 08:22 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thaxs Mr.P I'll look into this dry lube
