Help; correct booster and M/C for '70 B body
#164298
12/08/08 02:14 PM
12/08/08 02:14 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Hi guys,
I need some help. I'm finally getting ready for the final push on the 'Bee and as the car never came with a booster or M/Cyl I'm trying to figure out what is correct (and where to get it).
The car is my '70 Super Bee with (power) disk brakes. According to my Service Manual, I believe I should be using a Bendix booster (crimped rather than the clamped Midland Ross unit) and my master cylinder should be the tandem reservoir unit with the bale wire hold-down.
I've always been under the impression that Hemi cars had the brake lines connecting to the master cylinder on the fender side and all other motors had the lines connecting on the motor side of the master.
My questions are;
- Did only Hemi's get the Mcyl that had the fender side line connections?
- Am I looking for the correct booster?
- Are the backing plates different between drum/disk and or power/manual setups?
- Any assistance on where to procure the correct stuff would be appreciated.
Thx
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: Help; correct booster and M/C for '70 B body
[Re: Mastershake340]
#164300
12/08/08 04:15 PM
12/08/08 04:15 PM
Posts: 5,135 Kingsburg Calif.
Quikshft
Kingsburg Calif.
I can tell you for the master cylinder, you are correct. The non hemi disc unit has lines exiting toward the engine. If you want something that is very close to the original Bendix one, several sources including Napa have an aftermarket unit that is almost identical except for the numbers cast into the bottom.
I just purchased and installed the NAPA mastercylinder. It was not "exactly" like the original I had, but I figured for the time and trouble it saved me trying to rebuild the original (if possible) it's worth the money and the small difference in appearance. And, it does have lines exiting toward the engine as I understand is correct for all but hemi cars. As for your booster, I can post picture of my set up which I believe was original to the car later tonight.
[Re: Quikshft]
#164301
12/08/08 04:33 PM
12/08/08 04:33 PM
DPelletier
Thanks guys. I did get one from my local jobber and it was incorrect (had the bolt on cap). I'll try NAPA, but it'd be great if I could get a pic or two of the right one. Any pics of the correct booster would be great too: I have the (dis)pleasure off all this stuff missing off my car so I'm starting from scratch. Any ideas on the backing plates? Thanks again. Cheers, Dave
1974 'Cuda
#164305
12/08/08 05:27 PM
12/08/08 05:27 PM
DPelletier
Thanks for the pics; I agree, a coat of gloss black and that master would be good enough. There is a backing plate on the Hemi B bodies for sure, and I'm assuming on the others as well. Unfortunately the Service manual only shows drum brakes and "Power Brake Assembly (Bendix) Drum and Disc Brakes (426 Hemi Only)". Also , I *believe* that the backing plate on my car is original, but who knows with the amount of micky mousing that has gone on with this car in the past. Dave
1974 'Cuda
[Re: DPelletier]
#164307
12/08/08 07:57 PM
12/08/08 07:57 PM
DPelletier
I checked some more survivor pics and I now believe the plate needs to be there......but I'm sure there are several plates! The one I have has 2 studs (with four holes below for the booster) and a parallelogram shaped hole.
1974 'Cuda
[Re: DPelletier]
#164309
12/09/08 12:57 AM
12/09/08 12:57 AM
Posts: 18,160 Mass
DAYCLONA
Mass
Dave you need the Bendix booster, never saw a midland used in 70.......there are two plates, the one you have is for non-power,.....you can use it with a little surgery, lose the studs, you'll be useing the 2 upper, of the lower holes,If I recall?( or the two lowers?, whatever measures approx 4 1/8 bolt center line, vertically) and the ones where the studs were removed,( the studs face reward towards the passenger compartment? correct?) you need to reshape the hole for the booster pushrod,there's also a small intermediate linkage bellcrank, and small pushrod used,..... after the whole thing is mounted nobody can see the surgery.....you'll need the wire loom bracket that fits in the upper single hole and folds over the top of the booster, as far as the master, the new repro(lines inboard, towards the engine) is pretty close to the original.......Carquest # if I recall is Cardone M1614, and the Autozone # is Fenco M1475
[Re: Quikshft]
#164315
12/09/08 12:02 PM
12/09/08 12:02 PM
DPelletier
As far as you know is that booster original to the car? You don't want to sell your old MC do you? Dave
1974 'Cuda
[Re: DAYCLONA]
#164316
12/09/08 12:03 PM
12/09/08 12:03 PM
DPelletier
Thanks Mike; excellent info. Actually one of the magazine pics I saved was one of your '70. Does the power brake backing plate have a round hole by chance? Thanks again. Dave
1974 'Cuda
