Tire pressure suggestions 18" rim Falken 615K rubber? #1642900
07/06/14 03:15 PM
07/06/14 03:15 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Any suggestions for air pressures?
295/40/18 rear
315/30/18 front
Suggestions for regular street driving and autocross would be helpful!
Thanks Brad
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: brads70] #1642901
07/06/14 04:34 PM
07/06/14 04:34 PM
NorCal
RylisPro Offline
RylisPro  Offline
NorCal
295/40/18 rear
315/30/18 front
Thanks Brad
Wow you run a reversed staggered setup?
Haha!
73 `Cuda
Instagram: @rylispro
YouTube: RylisPro
www.rylispro.com
925-214-9192
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: RylisPro] #1642902
07/06/14 05:47 PM
07/06/14 05:47 PM
SoCal
MuuMuu101 Offline
I got lucky at Woodward!
MuuMuu101  Offline
SoCal
295/40/18 rear
315/30/18 front
Thanks Brad
Haha!
Technically since most the weight is in the front, it technically should help a little.
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: MuuMuu101] #1642903
07/06/14 09:27 PM
07/06/14 09:27 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
295/40/18 rear
315/30/18 front
Thanks Brad
Haha!
that's the idea..... car pushes when tires got hot. The other issue ( well... another issue lets say) is in stock form the track width is wider in the rear, hence the push.... fixed that too.
Any idea on what pressures to run?
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: brads70] #1642904
07/06/14 10:37 PM
07/06/14 10:37 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
The sidewalls on the 615k are pretty stiff, they can be run at fairly low pressure. I run 32 psi all around on street, 30 front 28 rear for autocross. Some of my competitors on them run as low as 26 F 22R....
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: Tomswheels] #1642905
07/07/14 01:10 AM
07/07/14 01:10 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Thanks for the reply. I was under the impression for autocross people added more air pressure.
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: brads70] #1642906
07/07/14 09:39 AM
07/07/14 09:39 AM
South
Squirrel_Cat Offline
South
I'd agree with what he mentioned as a base, in autocross, you want those tires to get hot as soon as possible since the run is so short. Lower pressures will help aid in that happening, cold tire grip [contact patch] is a big player overall.
1973 340 'Cuda 2013 Mustang GT
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: Squirrel_Cat] #1642907
07/07/14 06:52 PM
07/07/14 06:52 PM
The Netherlands
BigBlockMopar Offline
The Netherlands
Are those pressures with hot or cold tires?
I'm thinkin cold.
If cold, how much pressure do they end up with when hot?
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: BigBlockMopar] #1642908
07/07/14 10:43 PM
07/07/14 10:43 PM
Escondido CA USA
Tomswheels Offline
Tomswheels  Offline
Escondido CA USA
You are correct most tires need higher pressure for Autocross so the sidewalls don't roll over. I ran the Dunlop Z2 and they liked a bit more pressure, 38F and 36R. Lighter cars like Miatas always seem to like more pressure than heavy cars like ours. The pressures I use on the 615K are cold pressures, again with the 615 K you don't get huge pressure increases as the tire doesn't get overheated by falling over on itself. It's a very stable, planted tire in the corners and the pressure after most Autocross runs in my Valiant is rarely up more than 1 or 2 psi. Any more pressure increase than that and you're over driving...
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: Tomswheels] #1642909
07/08/14 06:36 PM
07/08/14 06:36 PM
Walnut Creek, CA
blown340 Offline
blown340  Offline
Walnut Creek, CA
I just use the old school shoe polish or chalk trick. Draw a line of shoe polish across the tread and down the sidewall. Make a run and adjust pressures so that the polish is worn off all the tread and just a little onto the sidewall. Do this on all 4 wheels each run until you have a consistent pressure that works for each tire.
70 challenger convertible. 340/5 speed. blown, intercooled, efi, blah blah blah 71 valiant scamp 318/A833OD/AC/PS 00 dakota RC 4.7L 5 spd autoX'r. SRT10/T56 swap in process 73 W200 Power wagon, PTO winch, 4 spd
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: brads70] #1642910
07/21/14 04:50 PM
07/21/14 04:50 PM
San Francisco Bay Area
MrAngry Offline
MrAngry  Offline
Hey Brad -
I run 615k's on my Mustang for road course duty - 315 squared set up. I start them out at 24 psi as hot temps climb to 34. For Auto-X you may want to start a bit higher though - maybe 25/26.
Just my
Never trust a pretty girl... or a lonely midget.
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: MrAngry] #1642911
07/21/14 06:59 PM
07/21/14 06:59 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Thanks!
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: brads70] #1642912
07/21/14 07:20 PM
07/21/14 07:20 PM
MrAngry Offline
MrAngry  Offline
That's a bad ass car right there...
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: MrAngry] #1642913
07/21/14 07:22 PM
07/21/14 07:22 PM
Houston Tx
Uhcoog1 Offline
Uhcoog1  Offline
Houston Tx
x2
-'02 Dodge Viper Ex-World Challenge racecar
-'73 Duster, 6.1 based 392 hilborn hemi, tko600, full floater rear 9", Hellwig custom bars, viper brakes, built for road course
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: MrAngry] #1642914
07/22/14 07:27 PM
07/22/14 07:27 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Thanks guys those fenders were a TON of work. I was expecting a lot of negative comments online and at Carlisle but nothing but positive remarks/questions. Mopar folks tend to lean on the purist side but so far so good. Not that it matters much. I like to do my own thing. I have the original fenders stored away in case I ever want to go back.
At Carlisle , Mopar Muscle asked to take pictures of it for their magazine, filled out a info sheet too. Cool stuff I thought!
Here is a few pictures of how I made them...
Bought an English wheel, never used on before?
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: brads70] #1642915
07/22/14 07:40 PM
07/22/14 07:40 PM
MD
RTSE4ME Online content
RTSE4ME  Online Content
MD
I like it!! You did a nice job.
You should do the rear also.
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: RTSE4ME] #1642916
07/27/14 03:16 AM
07/27/14 03:16 AM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
That looks great! I take it those are repop fenders that got the treatment? You might start a trend and be selling some 315 series front fenders for Challengers here.
What manufacturer for the 18" mini lite style wheels there?
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: PHJ426] #1642917
07/27/14 11:40 AM
07/27/14 11:40 AM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
Thanks, I expected to get almost run off this site doing this. Yes I bought new AMD fenders to cut up and stored my originals.
These are the rims... http://www.etwheels.com/lt_iii.html
With the hours involved... I don't think it would be a feasible venture making them!
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: brads70] #1642918
07/27/14 01:36 PM
07/27/14 01:36 PM
Fly Over States
P
PHJ426 Offline
PHJ426  Offline
P
Fly Over States
I hear that Brad.....the cornering section appears to be a bit more forgiving on modifications.
So how does the car feel with the 315/295 combo? I forgot your t/bar spring/swagger/shock setup.
Re: Tire pressure suggestions 18" rim Falken 615K rubber? [Re: PHJ426] #1642919
07/27/14 02:33 PM
07/27/14 02:33 PM
Ontario,Canada
brads70 Offline OP
brads70  Offline OP
Ontario,Canada
I have 1.120" t bars , 225 composite leafs, and double adjustable QA1's on all 4 corners.
Car is great I expected a horrible ride on the streets but it's not bad. The only negative issue is roads with ruts from transport trucks etc.... it follows the ruts pretty good. I got caught in a pretty good rain storm driving home from Carlisle ( 8 hour drive) and was having visions of having to grab a motel room but it was just fine , no hydroplaning at all. Slow manoeuvring like when parking is not an issue at all either! I have power steering with the fast ratio arms.
