Re: 340 not what I thought it would be...Any ideas?
[Re: RapidRobert]
#1642560
07/13/14 10:47 PM
07/13/14 10:47 PM
Posts: 464 KY
Telvis
KY
The slack is in the purple spring. Thats why it does the two stage with that spring combined with another non purple spring. The purple spring only engages once the advance reaches a certain point and slows it down as it goes all in. There's not really slack at idle. The non purple spring is holding the advance. It's just that the advance goes quick until the purple spring gets tension and slows it down. Listen to me...I sound like I know what i'm talking about! I swapped out the purple spring to another pink. It now has two pink springs and goes all in fast. I closed the slots a bit so that I get about 38 degrees all in. I have it set at 22 degrees initial. I took it up the road for a quick ride and it is definitely better. I think swapping the spring made the biggest difference yet. ![](/ubbthreads/images/graemlins/grin.gif)
That's King Weenie to you!
[Re: dogdays]
#1642564
07/16/14 08:23 PM
07/16/14 08:23 PM
Posts: 464 KY
Telvis
KY
[Re: Telvis]
#1642566
07/17/14 01:15 AM
07/17/14 01:15 AM
Posts: 3,119 N.W. Florida
Fat_Mike
N.W. Florida
I absolutely roasted the tires with no brake usage. I haven't even installed the new torque converter yet!!
That's addictive! You're probably gonna need to contact these folks before long: http://www.tirerack.com/ ![](/ubbthreads/images/graemlins/punkrocka.gif)
[Re: Fat_Mike]
#1642567
07/17/14 10:00 AM
07/17/14 10:00 AM
Posts: 15,487 Florida
scratchnfotraction
think it scratches now! wait till the TA3500 TC is in there.
got tires?
[Re: Telvis]
#1642570
07/18/14 02:59 PM
07/18/14 02:59 PM
Posts: 10,232 Someplace you aren't
SomeCarGuy
I'd double check the TDC mark. It sounds like it might be off a bit if you are running 40-42 total. I sent you a PM on a gear.
I want my fair share
[Re: SomeCarGuy]
#1642571
07/19/14 11:56 PM
07/19/14 11:56 PM
Posts: 464 KY
Telvis
KY
I got the new torque converter installed today. I just finished up a bit ago. It was too late to take it out. I will fill it up with trans fluid in the morning and give her a spin. I can't wait!
[Re: Telvis]
#1642572
07/20/14 01:32 AM
07/20/14 01:32 AM
Posts: 6,591 Canton, Ohio
Sport440
Canton, Ohio
![](/ubbthreads/images/graemlins/laugh2.gif)
[Re: Ramrod39]
#1642574
07/20/14 02:25 PM
07/20/14 02:25 PM
Posts: 464 KY
Telvis
KY
All I can say is Wow! I had no idea how much difference a good torque converter could make. Between the lower transmission gears, the fine tuning on the distributor and the torque converter my car is now officially a beast! It's almost scary now. I hammered it and it would not stop spinning! It spun all the way into second gear! I even punched it once when I was moving about 15 mph and it lit up the tires! I just came back from about a 45 minute ride. I now have about half the tire tread that I started with. I can't think everyone enough for all of the advice. I need to send an extra shout out to RapidRobert for all of his help. ![](/ubbthreads/images/graemlins/bow.gif) You guys are the greatest. I wish you guys could have seen the ear to ear smile on my face when I was roasting the tires! ![](/ubbthreads/images/graemlins/boogie.gif) I have my sights set on a set of 3:55 gears. I can't wait to see how that does. ![](/ubbthreads/images/graemlins/drive.gif)
[Re: dd340]
#1642576
07/20/14 02:37 PM
07/20/14 02:37 PM
Posts: 20,208 Park Forest, IL
slantzilla
Park Forest, IL
Congrats on your success! Personally, I would not waste my time going to a 3.55 from a 3.23. The actual return will be very small. ![](/ubbthreads/images/graemlins/Twocents.gif)
