Page 2 of 5 1 2 3 4 5
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642409
07/06/14 09:48 AM
07/06/14 09:48 AM
Truckville, the capital of NY
85_Ram_4speed Offline OP
Thanks, I will stick with the Scats then, as I have done in the past and will continue to do.
I do think some of you missed the part that where I said it will be essentially a stock rebuild and not raced. This application wont be raced not even a little bit, and should never see over 5000 RPM ---- just my opinion anyhow.
I love how Quicktree never answered my question to his "they suck" statement, LOL.
Outcast Dodge guy.
Re: Scat or Eagle for I beam rods [Re: 85_Ram_4speed] #1642410
07/06/14 12:31 PM
07/06/14 12:31 PM
Q
Quicktree Offline
Quicktree  Offline
Q
You must have missed where I said how many we have seen on here fail? Dan RIP performance only has showed several failed rods on basic stock builds. You can see and feel the poor quality. Just by looking at them I wouldn't use them. I have seen and touched them and they suck IMO so take that for whatever it's worth don't come Back whining if when they do.
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642411
07/06/14 01:08 PM
07/06/14 01:08 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I wouldn't run the Eagle SIR rods but the Scats are 4340 material.
Best so far, low 10.30’s 1/4
1.41 best 60 foot
6.56 at 104.17
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642412
07/06/14 01:09 PM
07/06/14 01:09 PM
No problem here Quick, sorry if I kinda called you out singlely, but if you go back and read your specific posts, you were pretty vauge on the whole thing---which was why I wanted to know your reasoning. The post right above this actually has more info than your other ones. That's all and it is all good here.
Thanks all for the replies, I will use the Scats as I wanted too in the first place. I was just thinking of the guys wallet a little, but I didn't want to sacrifice quality if I could help it.
Outcast Dodge guy.
Re: Scat or Eagle for I beam rods [Re: 85_Ram_4speed] #1642413
07/06/14 01:48 PM
07/06/14 01:48 PM
Lehigh Acres, Florida
rickstershemi Offline
Scat Cast 4" and I-Beams in the 408 I had built and sold.....The guy that bought it beats on it constantly....street / strip and it's still running strong.
Not a fan of over-spending when not needed
A lot of people cringed when we went with Compstar Components in the 565 as well, but it's still making laps and winning races and spent 2-years in Top Sportsman running 4.70's with a bunch of spray....now it's back in a local index car
Rickster
Re: Scat or Eagle for I beam rods [Re: 85_Ram_4speed] #1642414
07/06/14 01:52 PM
07/06/14 01:52 PM
P
Porter67 Offline
Porter67  Offline
P
I was just thinking of the guys wallet a little.
Actually you should be thinking of your wallet as well as your clients, as a rod failure in a modest build should not happen and you would be in the ringer if an sir rod failed.
Good info here from real world use. That is why I joined this site.
Some eagle parts are simply proven to be junk, sir rods and there cast crank are in that area.
The one shortcoming of the eagle H beam is if you like to road race, have a stick car or such where the motor sees on off, low/high/low rpm the small end bushing can wear quickly but when its time to replace the bushing itself you can use a better quality one.
Re: Scat or Eagle for I beam rods [Re: Porter67] #1642415
07/07/14 12:25 AM
07/07/14 12:25 AM
Toronto
mshred Online content
mshred  Online Content
Toronto
I have never heard anything bad about the Scat I beams, a good rod...the Eagles on the other hand, I have heard of more then enough that you couldn't pay me to run them.
Ran a set of Scat I beam rods for an entire season- about 70-80 passes and even more street beatings. When I took them out they were in great shape.
I think the Scat's are the way to go in this situation, thats my
Re: Scat or Eagle for I beam rods [Re: mshred] #1642416
07/07/14 09:20 AM
07/07/14 09:20 AM
Indy
FlyFish Offline
FlyFish  Offline
Indy
Scat I-beams in my 410 stroker, 5 years on this build, no problems, mid 10's, driven hard on a regular basis.
67 Barracuda street car, 408, e85, 1.38 60', 6.44 @105.9 in the 1/8 mile, 10.19 @130.5 in the 1/4...so far....
Re: Scat or Eagle for I beam rods [Re: FlyFish] #1642417
07/07/14 09:58 AM
07/07/14 09:58 AM
Q
Quicktree Offline
Quicktree  Offline
Q
I think most of you are missing the point, what is the cost of I beams? what is the cost of H beams? is it really worth it?
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642418
07/07/14 10:48 AM
07/07/14 10:48 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Plenty of high dollar rods are I beam, such as Oliver, etc, etc.
1.41 best 60 foot
6.56 at 104.17
Re: Scat or Eagle for I beam rods [Re: B3422W5] #1642419
07/07/14 12:45 PM
07/07/14 12:45 PM
P
Porter67 Offline
Porter67  Offline
P
Very true but thats another level of quality/cost.
Ive not done many I beams in the last 10 years, and used olivers actually.
I dont recall the bobweight or if the crank took metal.
Do the scat assemblies get weight taken or added to the crank, most common H beam builds seem to have some taken from the crank, if the I beams called for weight added then, hmmm.
Re: Scat or Eagle for I beam rods [Re: Porter67] #1642420
07/07/14 12:54 PM
07/07/14 12:54 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
My point was that Quicktree seemed to try and make the point that an I beam type rod was an inherantly bad design. That has zero truth to it
1.41 best 60 foot
6.56 at 104.17
Re: Scat or Eagle for I beam rods [Re: B3422W5] #1642421
07/07/14 01:10 PM
07/07/14 01:10 PM
Q
Quicktree Offline
Quicktree  Offline
Q
absolutely and at that level they are the best, but this cheap chinese junk i wouldn't put in a lawn mower. now the comp series stuff is pretty good, the H beam chinese rods are decent. the I beams are crap. the ones i have seen look like pot metal of old.
Re: Scat or Eagle for I beam rods [Re: B3422W5] #1642422
07/07/14 01:11 PM
07/07/14 01:11 PM
Q
Quicktree Offline
Quicktree  Offline
Q
i never said that at all........
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642423
07/07/14 01:26 PM
07/07/14 01:26 PM
Kalispell Mt.
HotRodDave Offline
HotRodDave  Offline
Kalispell Mt.
Quicktree you need to get your hand on a SCAT I beam before you condemn them, if the Chinese I beams you looked at look like pot metal you have not seen the SCAT you have seen the eagle. They are waaaaaaay better than the eagle all the way around from the bolt quality the material selection the machining quality, you don't have to pay extra to get a bronze bushed small end...
A SCAT I beam is a lot lighter than an H beam and will need material removed from most cranks, more so than the H beam.
To answer the OP question, run the SCAT if you can but don't forget to add in the cost of balancing, a step that could be(but really should not if possible) skipped on a tight budget with stock rods.
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642424
07/07/14 01:34 PM
07/07/14 01:34 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
You implied in that statement that if you can get an H beam for the price of an I beam, why wouldn't you do so.
IMO, same weight rod to same weight rod, of same material, the I beam has some strength benefits.
Btw, are you aware the Scat I beams are 4340 forgings,
The Eagle SIR rods are 5140
1.41 best 60 foot
6.56 at 104.17
Re: Scat or Eagle for I beam rods [Re: B3422W5] #1642425
07/07/14 01:41 PM
07/07/14 01:41 PM
Q
Quicktree Offline
Quicktree  Offline
Q
we were talking chinese crap, not oliver quality
Re: Scat or Eagle for I beam rods [Re: HotRodDave] #1642426
07/07/14 01:43 PM
07/07/14 01:43 PM
Q
Quicktree Offline
Quicktree  Offline
Q
run them if you like them, i have seen both and for the price difference i wouldn't use them
Re: Scat or Eagle for I beam rods [Re: Quicktree] #1642427
07/07/14 01:46 PM
07/07/14 01:46 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Doesn't matter what price point ..... 4340 is inherantly stronger than 5140, and there is no design liability in using an I beam over an H beam.
1.41 best 60 foot
6.56 at 104.17
Re: Scat or Eagle for I beam rods [Re: B3422W5] #1642428
07/07/14 01:55 PM
07/07/14 01:55 PM
A I beam versus a H beam rods made by the same company and with the same material for the same applictaion, the I beams are usually stronger and more expensive than the H beams A stock replacement rod is a different story than the I beams or H beams cap screw rods though
