Re: 4-speed gurus unite.
[Re: Rick_Ehrenberg]
#1641910
07/05/14 10:49 PM
07/05/14 10:49 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
If you didn't have this trouble before the u-joint issue, then I think a look inside that trans is in order...
In 50 years of messing with '833s, I've only found two causes for "popping out of gear"...
> Shift linkage maladjusted so the slider isn't 100% engaged
> Worn dog teeth on the speed gear (in your case, the main drive pinion). You have to look carefully, kind of a tapered or diagonal wear pattern.
Hard to imagine, though, how a bad u-joint could cause either of these defects. I'm thinking -- long shot -- bent / twisted mainshaft?
Rick
It was a rather violent failure. I kinda felt like I was in a rock polisher (except for the tumbling over and over part).
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: 69Y2RT]
#1641912
07/11/14 12:50 AM
07/11/14 12:50 AM
OhioMopar
Mt.Gilead, Ohio
I'll find out next week when I get to tear into it.
[Re: OhioMopar]
#1641913
07/12/14 01:38 AM
07/12/14 01:38 AM
Posts: 3,048 Richmond, Tx. (Houston)
GTSDave
My vote is for worn dogs on the high gear / main drive. My GTS is a 4 speed car and my 2nd gear pops out sometimes on deceleration. I know it's worn, but the car hasn't gone 10 miles since 1993....... Not high on my priority list to fix at this time I run a 4 speed in the Cuda, but it's a Jerico, an 833 wouldn't live in that thing. -Dave
PLEASE Pray for our brothers and sisters in harms way. If you are the owner of a GTS us at the GTS Registry www.gtsregistry.com
[Re: 71yelladustr]
#1641916
07/12/14 08:29 PM
07/12/14 08:29 PM
OhioMopar
Mt.Gilead, Ohio
I'm going to have it balanced fairly soon.
