4-speed gurus unite. #1641890
07/04/14 10:48 AM
07/04/14 10:48 AM
Mt.Gilead, Ohio
OhioMopar Offline OP
Mt.Gilead, Ohio
Car: '69 Super Bee. Trans:rebuilt 833. History: shifts fine, needs a little shifter and clutch adjustment. Cause(?): u-joint failure, driveshaft vibrating enough to hit the floor pan. New symptom:Under deceleration, pops out of high gear. Not violently. Just let off the gas and it shifts itself out of gear. It doesn't fight going back in, just pops our every time.
Question: Adjustment problem? Could the vibration (severe)have knocked somethinf loose or broken something inside? I'm also getting a vibration in the clutch pedal. I didn't notice it before, but it may have been there??
I just need to know if I'm going to need to pull the transmiasion out again, or maybe just adjust it.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: 4-speed gurus unite. [Re: OhioMopar] #1641891
07/04/14 01:11 PM
07/04/14 01:11 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
I have seen these U-joint failures shake so violently the advance plate shook loose inside the distributor. The same car cracked the bellhousing and extension housing too.
If all your adjusments are fine I wouldn't be surprised to find some internal damage.
Gus
64 Plymouth Savoy
Dana 60
Re: 4-speed gurus unite. [Re: fourgearsavoy] #1641892
07/04/14 02:05 PM
07/04/14 02:05 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Drat. I guess I'll pull it and open it up. It shook enough the console and glove box door popped open.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 4-speed gurus unite. [Re: OhioMopar] #1641893
07/04/14 03:31 PM
07/04/14 03:31 PM
A certified culture free zone.
74RALLYE Offline
74RALLYE  Offline
How would a transmission cause that much vibration?
I would try indexing the drive shaft 90 degrees different on the rear yolk. Check the U-joints and make sure all of the caps are mounted correctly and have all of their needle bearings in place.
Like OhioMopar said, loosing a U-joint can be very violent.
Re: 4-speed gurus unite. [Re: 74RALLYE] #1641894
07/04/14 03:43 PM
07/04/14 03:43 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
The u-joint came apart, that's what caused the vibration. Now I'm getting a popping out of 4th gear condition...
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 4-speed gurus unite. [Re: OhioMopar] #1641895
07/04/14 03:51 PM
07/04/14 03:51 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Sometimes, a picture just works...
Re: 4-speed gurus unite. [Re: RSNOMO] #1641896
07/04/14 04:07 PM
07/04/14 04:07 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
No point in ruining the car. 4-speeds are worth more for a reason. They're cooler.
(I don't recall me or any other kid thinking it was cool to shift into drive and race around the yard... )
Besides, a U-joint let's go behind that, I'm tearing down to replace a sparg.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 4-speed gurus unite. [Re: OhioMopar] #1641897
07/04/14 04:39 PM
07/04/14 04:39 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
You just run in the wrong circles...
A Hemi Torqueflite shifting is a beautiful thing...
(I lost a u-joint cup clip on the INTERSTATE...
The sprag survived just fine)...
And as far as values, yeah, a 4-speed might bring more...
But you need that, to cover the repair bills...
Step out of the dark ages...
A look inside a full-boogie Torqueflite is almost sexuhl...
Re: 4-speed gurus unite. [Re: RSNOMO] #1641898
07/04/14 04:44 PM
07/04/14 04:44 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
I can look inside a full-boogie Torqueflite when it explodes.
I drive mine hard. I'll get it stabilized and it will be more fun that an auto. Noone looks in a car to see if it is an auto.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 4-speed gurus unite. [Re: RSNOMO] #1641899
07/04/14 10:51 PM
07/04/14 10:51 PM
Rittman Ohio
Rittman Ohio
You left out the skirt, heels, and purse in that picture of the girl's muscle car transmission. Real muscle cars have three pedals.
Slushboxes are for women
Gus
64 Plymouth Savoy
Dana 60
Re: 4-speed gurus unite. [Re: fourgearsavoy] #1641900
07/05/14 04:40 AM
07/05/14 04:40 AM
Mi,U.S.A.
mike s Offline
mike s  Offline
Mi,U.S.A.
Gus
Yea what he said!
Leave the gun.......take the Cannoli's....Mike
Re: 4-speed gurus unite. [Re: mike s] #1641901
07/05/14 11:53 AM
07/05/14 11:53 AM
Georgia
Steve Bryant Offline
Georgia
So I have to admit that once I replaced my mushy auto with a 4-Speed in my Cuda, I now get that admiring comment from admirers "Oh wow, you have a 4-speed". NO-ONE says "Oh wow, you have an automatic"
Not to mention the fact that you "feel" your car so much better. An Automatic is like a buffer between me and the drive train. If I were racing or older I could see some benefit to an automatic but for street, overall feel/control and connecting with the car I'll take my 4-speed any day of the week. I am glad I made the change.
Now if I just find a nice 4-speed center console top plate for less than $150 I'd be happy.
Re: 4-speed gurus unite. [Re: fourgearsavoy] #1641902
07/05/14 03:10 PM
07/05/14 03:10 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
Gus
Yeah, sure they are...
Why don't you tell everybody how many times you've been waxed by a 'slushbox'???
Autos have been pounding Ronnie wanna-be's in these parts for many years...
Re: 4-speed gurus unite. [Re: RSNOMO] #1641903
07/05/14 03:22 PM
07/05/14 03:22 PM
BDW Offline
BDW  Offline
I've always wondered why 4spd cars sell for more than autos.
The auto was an expensive option, so there were less made?
In reality almost no 1 can "out shift" and auto?
It is just the nostalgia factor?
Re: 4-speed gurus unite. [Re: BDW] #1641904
07/05/14 03:40 PM
07/05/14 03:40 PM
NY
70440+6bbl Offline
70440+6bbl  Offline
NY
Untrue, in most every case, the automatics outsold the manual trans.
Given the choice, I would never buy an automatic muscle car (have owned over 100 in nearly 27 years, 99% of them were factory 4-gear cars)... Nor would most enthusiasts that I know. We all know that autos have the potential to be more consistent, but that's irrelevent to me, as I'm not out racing every Tom, Dick and Harry on the street. Bench seats and pistol grips, that's where it's at!!!
'70 Super Bee 440 6 pack 4-spd 4.10 Dana N96 EB5
‘70 Super Bee 440 6 pack 4-spd 3.54 Dana FC7
‘70 ‘Cuda 440+6bbl 4-spd 3.54 Dana N96 EB5 V1W
Re: 4-speed gurus unite. [Re: 70440+6bbl] #1641905
07/05/14 05:54 PM
07/05/14 05:54 PM
Mt.Gilead, Ohio
Mt.Gilead, Ohio
Anyone got any more ideas on what causes a trans to pop out of 4th.
Enjoyable derailment of the thread, but I still have the same issue!
1969 Dart GTS 340
2015 Dodge Dart GT
Re: 4-speed gurus unite. [Re: OhioMopar] #1641906
07/05/14 05:56 PM
07/05/14 05:56 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Chipped tooth on a gear.
Re: 4-speed gurus unite. [Re: OhioMopar] #1641907
07/05/14 05:58 PM
07/05/14 05:58 PM
RSNOMO Offline
Moparts Torchbearer
RSNOMO  Offline
Moparts Torchbearer
If you didn't have this trouble before the u-joint issue, then I think a look inside that trans is in order...
Re: 4-speed gurus unite. [Re: RSNOMO] #1641908
07/05/14 07:08 PM
07/05/14 07:08 PM
Rittman Ohio
Rittman Ohio
Gus
Sounds like a challenge that I'm up for are you???
I went 11 rounds once against mostly glides and a few T-flites thrown in for the win in Pro a few years ago.
It's all about the shifter and the talent of a fast hand and left leg
Gus
64 Plymouth Savoy
Dana 60
Re: 4-speed gurus unite. [Re: RSNOMO] #1641909
07/05/14 09:43 PM
07/05/14 09:43 PM
Marlboro, NY, USA
Rick_Ehrenberg Offline
Marlboro, NY, USA
In 50 years of messing with '833s, I've only found two causes for "popping out of gear"...
> Shift linkage maladjusted so the slider isn't 100% engaged
> Worn dog teeth on the speed gear (in your case, the main drive pinion). You have to look carefully, kind of a tapered or diagonal wear pattern.
Hard to imagine, though, how a bad u-joint could cause either of these defects. I'm thinking -- long shot -- bent / twisted mainshaft?
Rick
