Re: 70 440-6 Engine Detail
[Re: Stewpar]
#1641676
07/03/14 01:01 PM
07/03/14 01:01 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
Hmmm; maybe somewhere in my "stuff", if nobody chimes in, I'll see if I can find it. I do have a few survivor pics if there is anything specific you are looking for.
Cheers, Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
[Re: steve70]
#1641681
07/03/14 01:50 PM
07/03/14 01:50 PM
Posts: 892 MA
steve70
MA
2nd one. I think it's November and December 2013.
[Re: Stewpar]
#1641683
07/03/14 05:13 PM
07/03/14 05:13 PM
Posts: 18,172 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#1641684
07/03/14 05:17 PM
07/03/14 05:17 PM
Posts: 18,172 Mass
DAYCLONA
Mass
[Re: DAYCLONA]
#1641685
07/03/14 06:16 PM
07/03/14 06:16 PM
RSNOMO
Moparts Torchbearer
Moparts Torchbearer
Anything specific?......
Yep...
Orange, with 3 Holley's shor' looks good with some contrast...
(As in pic 1)...
[Re: 1cuda]
#1641688
07/04/14 10:43 AM
07/04/14 10:43 AM
Posts: 18,172 Mass
DAYCLONA
Mass
i think that carbs were on before paint and masked off but there seems to be a lot of orange between the carbs on that plum crazy car. what do others think? this pic is of an original paint a12 car- i know it`s not 1970 but if anyone has seen the frank badalson video on the fc7 440-6 cuda he actually removes a piece of masking that was still there on the low mile original. all the best frank.
I don't know if I'd "buy" the carbs on during paint deal, perhaps a "mask" for the gasket area where the carb's base mounted to?, I'm sure no 2 engines were painted identical by the engine shop, variations wil exsist, just like in individuals restorations, some my look to employ the haphazardness of a "factory finish", others what a factory look, but an eye towards "neatness", others want detail/rolling art....
Mike
[Re: RealWing]
#1641690
07/04/14 03:24 PM
07/04/14 03:24 PM
Posts: 2,963 Wisconsin
Stewpar
Wisconsin
There was a Roger Gibson article out there somewhere with detailed pictures, does anyone have it?? Thank you!!
Is there something specific or are you looking for all details?
It was the article as a whole, besides the verbiage, there were real detailed pics of a motor on a cradle. The spark plug shield, etc. etc. etc.
If someone has it and can post the entire 4-5 page article, it would be greatly appreciated!!!
Happy 4th!!
[Re: ScottSmith_Harms]
#1641692
07/04/14 04:31 PM
07/04/14 04:31 PM
Posts: 18,172 Mass
DAYCLONA
Mass
There's one pretty obvious detail that is incorrect on all but one of the Six Pack carbs posted on this thread, can any of you spot it?
It would be the negative cable position on top of, instead of under the throttle bracket in the above pic of Alan Galant's engine, actually the "barrelcuda" 71 Cuda
Or the missing limiter plastic cap for the idle mixture screw on the purple 70 B body....
or.....
or....
#1641695
07/04/14 05:03 PM
07/04/14 05:03 PM
Posts: 18,172 Mass
DAYCLONA
Mass
Nope, none of those are the detail I'm looking for
throat gaskets....
[Re: 44D6PAKCUDA]
#1641696
07/04/14 05:06 PM
07/04/14 05:06 PM
Posts: 42,714 Spokane Washington
ScottSmith_Harms
Mr Wizzard
Mr Wizzard
Spokane Washington
Ok, But it's a tough/expensive one to correct 100%. The throttle shafts should be a dark color, they were not the same gold color as the throttle arms, etc. The problem is that the shafts were coated before the gold plated throttle arms were added to them. Because of the way the factory attached them they are not removable for restoration/re=plating. The star burst looking area in the center of the arms are the ends of the shafts peened over to retain them and are not removable, these star burst areas were also dark colored. So far as I am aware there are only two ways to go, make an effort to make the shafts dark after plating the entire shaft gold, or (the more expensive way) buying brand new bases with factory darkened shafts already installed. When I restore them I plate the shafts gold first and dip the shafts dark to the arms. This can not work on the center carb in between the double throttle shaft arms, or the end star burst areas. In addition, these areas that can't be dipped can be hand colored with paint or ink markers for a faux dark finish, it looks closer than plain gold but is still short of what the new bases offer in terms of exacting correctness. *Also, the example Cuda1 posted is a bit deceptive as it looks gold....It isn't, either the camera flash made it look lighter than it is, or it's just faded to a lighter shade with age, they were darker when new, not black, just a dark brownish color
#1641698
07/07/14 10:28 AM
07/07/14 10:28 AM
Posts: 9,336 South-Central (Sebring), FL
Commando1
Ok,
