More testing with 2013 EMC 466
#1641640
07/03/14 09:29 AM
07/03/14 09:29 AM
Posts: 1,051 The Great White North
RAMM
About 2 weeks ago I received a text from a friend telling me their 540/440-1 headed bracket car engine had experienced rocker/lifter failure. I jokingly suggested the owner of the car purchase the 466 I had run in the EngineMasters Challenge last year. Well one thing led to another and I offered to install the larger cam I actually ran in our 471 in the EMC '09 and lend them the engine--(mainly I wanted to see what it would run in a fairly well sorted bracket car).
At this point I had an assembled short block on the stand (thanks to my comrade Joe Rutters) and I still had to refresh the heads and finish the entire assembly.
The changes to the basic configuration were a little more head milling, bigger exhaust valves 1.75"-1.81", more duration cam 269/269 @ .050" same lift, and a Wilson 4 hole spacer.
Last Friday we got it on the pump and made a total of 8 pulls. I was hoping for an honest 750 HP on our dyno considering the best pull last year was 726 HP. Needless to say it was a good Friday. J.Rob
2009 PHR\EMC Competitor 2010 PHR\EMC Competitor 2011 PHR\EMC Competitor 2012 PHR\EMC Competitor 2013 PHR\EMC Competitor 2014 HotRod/EMC Competitor 2015 HotRod/EMC NoShow 2016 HotRod/EMC 3rd place SPEC Bigblock 2018 HotRod/EMC 7th place G3
Re: More testing with 2013 EMC 466
[Re: RAMM]
#1641641
07/03/14 09:31 AM
07/03/14 09:31 AM
RAMM
Here is a comparison graph of last years configuration vs. current config. The red line is obviously the current config. J.Rob
[Re: RAMM]
#1641642
07/03/14 09:32 AM
07/03/14 09:32 AM
RAMM
Here is where it is currently residing. J.Rob
[Re: Triple Threat]
#1641644
07/03/14 02:22 PM
07/03/14 02:22 PM
Posts: 3,210 robin hood country
deaks
robin hood country
What's the rest of the spec and is this a low deck ? I would also like to see the results along with the weight of the car. Mick
69 Dart GTS 440 mopar .590 cam, Edelbrock heads, 3200# best et 6.45, 106.78, 10.14, 132.88 mph, 1.47 60ft best 60ft 1.36
