finally got my 05 magnum r/t to the track #1641539
07/03/14 01:59 AM
07/03/14 01:59 AM
ON, Canada
AMC400Mopar Offline OP
ON, Canada
I had fun tonight at the track in my magnum wagon. I definitely have a lot to learn about drag racing before we get our Javelin finished. Anyway, my best run was 14.478 at 97.12 mph. Air temp was 84F and very humid. My 2005 magnum r/t is stone stock and had half a tank of cheap 87 octane fuel.
I played with a few easy things between runs. I learned that I was a little slower with the traction control switched on. I gained nearly .5 mph by removing the air filter element. Auto or manually shifting made no difference; I ran 3 passes back to back at about 14:61 (14.617, 14.613, 14.593) with the 2nd pass being manual shift. So I just left it in drive after that.
Tire pressure is my big question. I dropped rear psi to 25 but it hurt my 60 foots by 15/100ths. What kind of tire pressure do you guys run at the track in your normal all season radials?
Anyway, I had a ball at the track, learned a lot and can't wait to try again soon!
Re: finally got my 05 magnum r/t to the track [Re: AMC400Mopar] #1641540
07/03/14 09:23 AM
07/03/14 09:23 AM
Norwalk Ohio
cudasteve68 Offline
cudasteve68  Offline
Norwalk Ohio
Do not lower the tire pressure on a normal radial tire. It works the opposite of bias-ply slick.
Re: finally got my 05 magnum r/t to the track [Re: cudasteve68] #1641541
07/03/14 09:30 AM
07/03/14 09:30 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
get a Diablo tuner... I dropped almost a second off my et in my old 06 AWD Mag R/T. My best time was 14.06. Leave it in D. You can change the shift points as well as frimness of shift w/ the tuner. I also changed my thermosat to 180* changed the fans, removed the goofy engine cover and iced the intake between rounds (not sure if that helps or not) because it's usually hot and humid here in Md. A 2wd should run 13's easy.
Coming soon!!!!
Re: finally got my 05 magnum r/t to the track [Re: Mr.Yuck] #1641542
07/03/14 12:42 PM
07/03/14 12:42 PM
ON, Canada
ON, Canada
thanks for the tips! I will put the diablo tuner on my wish list and let you know how it works out. It'd be nice to break into the 13's with this thing!
Did the 180 thermostat help much? Or should I try a 160? All I did between runs was crank the heater on full blast and roll down the windows...
Re: finally got my 05 magnum r/t to the track [Re: AMC400Mopar] #1641543
07/03/14 01:23 PM
07/03/14 01:23 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The T-stat helps the shifts on my SRT Challenger. They are a lot crisper now. If I drive it any when its real cold out I get a code about it not warming up enough but the preditor will clear it. That's with a 180 T-stat.
I think I get my best 60' with tire pressure at 35psi. Been hi 1.7's. and 7.70's in the 1/8 at 91mph. All on a 275 wide BFG on the stock 20" rim.
Those numbers are at 5psi out of the Procharger.
Re: finally got my 05 magnum r/t to the track [Re: FastmOp] #1641544
07/03/14 04:54 PM
07/03/14 04:54 PM
east coast
Otherlane Offline
Otherlane  Offline
east coast
I've been racing my 2011 dodge avenger and went 14.70 than got a tuner than posted 14.00 bone stock. Amazing what a tuner will do to these cars
