Re: Need an education on pushbutton shift transmissions [Re: dOrk !] #164081
12/09/08 10:01 AM
12/09/08 10:01 AM
Not2farfromNashville, TN
Rug_Trucker Offline
Rug_Trucker  Offline
Rear pump? You can actually push start them. I have a 65BB stashed.
Hey RT ...I will pick up that 65 trans along with that 383 block if you don't need it !!
Just wrap those "Electric Bananas" with green backs.
"The only thing to do for triumph of evil is for good men to do nothing"
"NUNQUAM NON PARATUS!"
Re: Need an education on pushbutton shift transmissions #164082
12/10/08 12:11 AM
12/10/08 12:11 AM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Need an education on pushbutton shift transmissions [Re: hemi-itis] #164083
12/10/08 12:23 AM
12/10/08 12:23 AM
Madison Wi
NTOLERANCE Offline
NTOLERANCE  Offline
Madison Wi
IF youd like to get away from the ball and trunion but dont want to go through the whole changing the rear shaft deal, I did see where a guy installed a Dodge truck U joint onto the back of a ball and trunion trans. It was a 4 speed, but I cant imagine they are different. The front yoke bolted to the trans, then a U joint, then the drive shaft. Was a bit of custome work, but its easier to service then the ball an trunion. He didnt know what the parts came from, just "Dodge truck"
Re: Need an education on pushbutton shift transmissions [Re: John_Kunkel] #164084
12/12/08 12:00 AM
12/12/08 12:00 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
John, as long as I've worked on transmisions you never fail to expand. It seems I learn something new every time you post. I always enjoy your input.
Thanks Doug
