small block 59 and 48 degree
#1640301
06/30/14 03:08 AM
06/30/14 03:08 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
when do you see or need the benefits of a 48 degree over a 59 degree 416 w5 spinning 8000
Re: small block 59 and 48 degree
[Re: Quicktree]
#1640303
06/30/14 09:55 AM
06/30/14 09:55 AM
Posts: 733 jacksonville,FLORIDA
slammedR/T
When you want a head that makes more power
2000 Dakota R/T, 408 magnum, 727, Indy heads 1000cfm 4150 carb, 93 octane fuel. motor; 10.258 @ 132.78 200 shot; 9.262 @ 144.69 racemagnum
[Re: Quicktree]
#1640304
06/30/14 10:04 AM
06/30/14 10:04 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
the lifter angles going to make more power spinning at same rpm ????
[Re: Belvedere2]
#1640306
06/30/14 12:39 PM
06/30/14 12:39 PM
Posts: 3,978 Hilltown Pa
1967dartgt
Hilltown Pa
It gets the pushrod pinch out of the way, better head castings that make more power. More stable valvetrain for more hp and reliability. Fit larger pushrods more lift just much better design.
Brett Miller W9 cnc'd heads STR Chassis fabraction
[Re: RAY1969CARS]
#1640308
06/30/14 04:34 PM
06/30/14 04:34 PM
Posts: 20,647 in a cattle trailer down by th...
Guitar Jones
I'd say you are right on the edge there. My W5 340 would start knocking the adjusters loose over 8K. That had to be some pretty serious shakin' going on in there.
[Re: Guitar Jones]
#1640309
06/30/14 05:56 PM
06/30/14 05:56 PM
Posts: 52,972 Romeo MI
MR_P_BODY
Once I went with T&D rockers my 59* blocks worked fine up to 8200 rpm but I didnt go higher(didnt need to) but I have gone WAY HIGHER on my 48*
[Re: MR_P_BODY]
#1640310
06/30/14 06:13 PM
06/30/14 06:13 PM
Posts: 252 St.Louis, Mo.
mokid
St.Louis, Mo.
Did you see HP improvements over 8000 RPM I currently run a W8 R3 48dg we just start bumping our shift up to 8000 in 2nd and 3rd
[Re: mokid]
#1640311
06/30/14 06:23 PM
06/30/14 06:23 PM
MR_P_BODY
I was trying to find more power.. my cam lift was way to short and never found any more past 8200.. but if your in the .800+ lift you should find more.. I was in the .710 lift range
[Re: mokid]
#1640313
07/01/14 09:22 AM
07/01/14 09:22 AM
slammedR/T
I turn mine 8k rpm with the T&D rockers on my 360-1 cnc heads and stock magnum block.
[Re: 1967dartgt]
#1640315
07/01/14 02:09 PM
07/01/14 02:09 PM
Guitar Jones
I'd say you are right on the edge there. My W5 340 would start knocking the adjusters loose over 8K. That had to be some pretty serious shakin' going on in there. :
how much power is to be had out of a 416 after 8000 rpm with scat lightweight forged crank h beam rods and ross dome pistons
Depends on your heads and cam.
I'm thinking unless you have some real serious heads and cam you are already on the downward side of the curve at 8k.
[Re: RAY1969CARS]
#1640317
07/15/14 01:11 AM
07/15/14 01:11 AM
MR_P_BODY
What timing chain are you guys running on your 48° blocks tall decks???????
I use the KB gear drive
[Re: MR_P_BODY]
#1640318
07/15/14 01:13 AM
07/15/14 01:13 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Can a chain be used ????
[Re: RAY1969CARS]
#1640319
07/15/14 01:15 AM
07/15/14 01:15 AM
MR_P_BODY
Sure... just use a quality one
[Re: MR_P_BODY]
#1640320
07/15/14 01:49 AM
07/15/14 01:49 AM
Posts: 1,390 CA.
RAY1969CARS
CA.
Quality one ?? Are that longer then a reg A block ?? The r block I'm looking at is a tall deck 48 degree with std cam bearings
