Rear brakes act warped cold & fresh from machine shop
#1638080
06/24/14 09:03 PM
06/24/14 09:03 PM
Posts: 817 Eugene, Oregon
Secret Chimp
Eugene, Oregon
I have 11x2.5 inch rear drums on my Coronet wagon and I can't figure out why they aren't running true.
Before taking them off to be machined & reinstalling them with new shoes, either wheel would catch on a higher spot on the drum when I tried to adjust them out, and you could feel the rear end pulsing under braking.
A couple years ago I took them off, had them turned, and threw them back on, still had the problem, but said "eh" as I wasn't driving the car like I do now. Back then the guy who helped me said it didn't even look like they'd been turned before
This time, the drums were machined to 11.059 and 11.060 by the same automotive machine shop here (not parts store) and immediately after bolting the wheels back on – car in the air, lugs hand-tight, both drums still dead cold and never used - the drums still don't drag evenly and in fact act almost the same as pre-machined, again.
I can't adjust the shoes out for slight drag because either drum catches on a certain spot as if it's warped. So right now I have slight drag across the area the shoes want to catch on and then they're too far in for the rest of the rotation. This still manifests if I have the wheels off (the wheels aren't warping otherwise-straight drums).
What could be out of whack in my rear end that would cause this? Or could the drums somehow just be off in a dimension that wouldn't appear on a lathe? Ordinarily I'd just throw new parts at this, but I can't find 11x2.5 rear drums for a decent price anywhere.
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Rear brakes act warped cold & fresh from machine shop
[Re: Secret Chimp]
#1638082
06/24/14 09:06 PM
06/24/14 09:06 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
bent axle shaft?
Gonna have to put a dial indicator on the drum and shaft to narrow things down.
[Re: Secret Chimp]
#1638083
06/24/14 09:13 PM
06/24/14 09:13 PM
Secret Chimp
Eugene, Oregon
This happens on both sides, not just one or the other. I had been wondering if my axles could be bent or if the bearings are junk - when I got the car the rear end preload was pretty loose (like a good 3/4 inch back and forth). I knocked it back in to spec and it's still in the ballpark a couple years later.
[Re: Secret Chimp]
#1638087
06/25/14 09:23 AM
06/25/14 09:23 AM
Posts: 21,072 Niles , Ohio
therocks
Niles , Ohio
Did you change the shoes also?Ive installed new drums and shoes and found some with slight hi spots.They used to arc the shoes to the drums years ago.Now they dont as no one has the equipment.Does the car sort of hop when you use the brakes?Rocky
Chrysler Firepower
[Re: Secret Chimp]
#1638091
06/26/14 01:01 PM
06/26/14 01:01 PM
Posts: 667 Los Osos, Ca
CKessel
Los Osos, Ca
See if you can scare up another pair of drums. Maybe a freind has a pair on his car to switch out. I know from working in the parts industry that you have to store drums laying flat not sitting verticle. If they have sat verticle, they can get egg shaped. Rotors are not as touchy. Something else you can try is to put them on inside out to check with a dial indicator. May not work well though if the center hole is a loose fit on the axle center pilot stub.
Carl Kessel
[Re: Secret Chimp]
#1638094
06/27/14 09:39 AM
06/27/14 09:39 AM
therocks
Niles , Ohio
I had one at work that I did new drums etc on.Used hi buck Bendix drums.Went for a ride and when I hit the brakes it felt like the rear was coming out of the car.Replaced the drums and problem was gone.Sometime the shoes arent centered also and it will cause a drag on hi/low spots.Drums can have a hard spot also even if they were turned.Rocky
Chrysler Firepower
[Re: therocks]
#1638095
06/27/14 12:50 PM
06/27/14 12:50 PM
Posts: 5,102 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
Sounds to me like 1 of maybe 2 things. 1st would be that the center hole in the drum is larger than the axle flange and is no longer hub centric. 2nd as previously mentioned the axles could be slightly bent. I would flip the drum over on the axle (install it backwards) and check it for run out.
...FAFO...
[Re: nomore65BelvJim]
#1638097
06/29/14 12:38 AM
06/29/14 12:38 AM
Secret Chimp
Eugene, Oregon
Fun developments! I knocked my left drum off and the axle flange itself runs dead true. I put the drum back on backwards to see how runny-outy it was: http://www.youtube.com/watch?v=D8NCBcsbNCAhttp://www.youtube.com/watch?v=buVdvrEs0cQHere you can see how the axle isn't contributing to the wobble (I know sideways, sorry): http://www.youtube.com/watch?v=MS5FoI0OV8QSooooo... bonus points for everyone who guessed the drums vs the axles. They are mounted against a spare set of nuts screwed down all the way, not against the flange (would not sit flush backwards). Any tips on where to look for 66-74 11x2.5 rear drums? I can't even find them indexed in most places I usually shop (Summit, RockAuto, Jegs, Amazon). I've only located one vendor – they don't offer actual part numbers for cross-reference and they want $120 apiece: http://www.jimsautoparts.com/brake.htmUnless there's some miracle chance of machining this out?
[Re: ahy]
#1638099
06/29/14 01:16 AM
06/29/14 01:16 AM
Secret Chimp
Eugene, Oregon
I got a set of 11x2.5 drums a few years ago from Year One (E). Looks like they still carry them. Rock Auto has some also (4 left on the one I looked at).
https://www.yearone.com/Catalog/1966.74....s/rear-.-e.body
=0&ck[idlist]=0&ck[viewcurrency]=USD&ck[PHP_SESSION_ID]=ooomu6q5omrl4068hfum1bdld4]http://www.rockauto.com/catalog/raframec...l4068hfum1bdld4
Cool... maybe. These don't exactly match when they have specs, so this is where I'm unclear about things I can ignore and things I shouldn't.
I looked up the Bendix PDR0365 they had listed there, and they only x-reference it for 69 and up B-bodies. I measured my drum vs this one and there's about a half inch in overall height (depth?) difference - 3.9 inches for mine vs 4.4 inches for the new one.
I dunno if that means nothing, if they're going to hit my backing plates or be misaligned with the shoes, etc.
YearOne also only lists 10 x 2.5 drums for B-bodies. Did you use E-body drums in a B yourself?
[Re: ahy]
#1638101
06/30/14 08:12 PM
06/30/14 08:12 PM
Secret Chimp
Eugene, Oregon
I finally checked my actual runout - one axle barely had .005", the drum (mounted normally, measured at the edge of the friction surface) had .038". The other axle indicated .012" – at that point I figured "close enough for now" and went and ordered some Challenger-spec drums from O'Reilly's. Hopefully when I put them on tonight or tomorrow that'll be the end of this mystery (otherwise Dr. Diff's getting more of my money for axles)
[Re: Secret Chimp]
#1638102
07/01/14 12:13 AM
07/01/14 12:13 AM
CKessel
Los Osos, Ca
Check them to see if they are out of round before you use them.
Carl Kessel
