Re: Rear brakes act warped cold & fresh from machine shop [Re: Secret Chimp] #1638100
06/29/14 01:33 AM
06/29/14 01:33 AM
IN
ahy Offline
ahy  Offline
IN
On the specs... my car is an "E". I don't "think" there was any difference in important specs on drums for "B" and "E". Some were finned for cooling and some were not which affects outside diameter but not the "working" dimensions. I did double check the Y1 link and it is for 2.5" x 11". Good luck!
Re: Rear brakes act warped cold & fresh from machine shop [Re: ahy] #1638101
06/30/14 08:12 PM
06/30/14 08:12 PM
Eugene, Oregon
Secret Chimp Offline OP
Eugene, Oregon
I finally checked my actual runout - one axle barely had .005", the drum (mounted normally, measured at the edge of the friction surface) had .038". The other axle indicated .012" – at that point I figured "close enough for now" and went and ordered some Challenger-spec drums from O'Reilly's. Hopefully when I put them on tonight or tomorrow that'll be the end of this mystery (otherwise Dr. Diff's getting more of my money for axles)
1967 Dodge Coronet Deluxe station wagon
1.03" T-bars, QA1 arms/rods, Cordoba/GM Metric/Volare brake & knuckle, XHDs, Hellwig rear sway, 318 Magnum w/ air gap, 727, 3.23s
Re: Rear brakes act warped cold & fresh from machine shop [Re: Secret Chimp] #1638102
07/01/14 12:13 AM
07/01/14 12:13 AM
Los Osos, Ca
CKessel Offline
CKessel  Offline
Los Osos, Ca
Check them to see if they are out of round before you use them.
Carl Kessel
