Door Sill plates #1637370
06/23/14 12:13 PM
06/23/14 12:13 PM
Vesper,Wisconsin U.S.A
DusterJeff Offline OP
I,m having trouble finding a replacement set of door sill plates for my 1990 w-250 truck.Made of aluminum,only 1 was on the truck.I am in the process of replacing the floor pans in it,will put in a new vinyl floor with jute backing to replace the original.It is my Daily driver or work truck.Just fixing a little at a time on it. Can anybody recommend a source????
Do Something..Lead..Follow..or get the {Beep} out of the way..
Re: Door Sill plates [Re: DusterJeff] #1637371
06/23/14 12:24 PM
06/23/14 12:24 PM
Buford, GA
I_bleed_MOPAR Offline
Buford, GA
About 10 yrs. back I had looked and looked for a clean set for my freshly painted '85 W150. I bought some for a mid-80s Grand Cherokee (the full-sized one) and trimmed them to fit. Heavier aluminum than the originals and were only a few dollars at the local pull-a-part.
Someone mentioned that they were still available new (at least back then).
Edit: Found my original post. They stuck it in the tech archive.
https://board.moparts.org/ubbthreads/showflat.php?Number=768586&page=17
Tim
'71 Charger 383/727
'17 Challenger SXT (Wifeys car wink )
Re: Door Sill plates [Re: DusterJeff] #1637372
06/23/14 12:45 PM
06/23/14 12:45 PM
Crockett ,TX
9
98RAM1500 Offline
98RAM1500  Offline
Crockett ,TX
www.lmctruck.com has them now, they finally got 72-93 dodge truck parts good price on the sill plates as well
Re: Door Sill plates [Re: 98RAM1500] #1637373
06/23/14 05:36 PM
06/23/14 05:36 PM
Orange Park FL.
LilRed7879 Offline
LilRed7879  Offline
Orange Park FL.
I am not sure the later years are the same as the early years but we have had these for a long time -
http://www.dodgeconnection.com/catalog/item/2822668/5228163.htm
http://www.dodgeconnection.com/catalog/item/2822668/3930424.htm
David S.
Part Time Owner
Dodge Connection
904-209-9388
Re: Door Sill plates [Re: 98RAM1500] #1637374
06/24/14 11:35 AM
06/24/14 11:35 AM
Thanks for your help guys.......Much Appreciated.....
Re: Door Sill plates [Re: LilRed7879] #1637375
06/24/14 04:24 PM
06/24/14 04:24 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
David, they are the same ones
