MPG question diesel 5.9 VS 6.7 on 2500/3500 megacab
#1637362
06/23/14 12:12 PM
06/23/14 12:12 PM
Posts: 2,336 Ball Ground, Georgia
Dixie
Hey Guys, I heard on the news, new cars sales are at a record high since the economic turn down. As such, 1-3 year old used cars are a "deal" now. I've been interested in a Mega-cab diesel for awhile. What MPG have you guys been getting with the 5.9 and 6.7 engines? I heard the 6.7 got worse, and higher maintenance cost's with the new emissions stuff. Is there a preferred year for the 5.9 for power/economy/reliability? 6.7? While most of my usage will be towing, I was considering 4WD for the rare instance I get stuck in the mud. What is the mileage difference if you add 4WD? Thanks for your input!!
Re: MPG question diesel 5.9 VS 6.7 on 2500/3500 megacab
[Re: Dixie]
#1637366
06/26/14 11:25 AM
06/26/14 11:25 AM
Posts: 13,376 Marion, South Carolina [><]
an8sec70cuda
w/ what they said. Definitely get a 4x4...a 2wd diesel will nearly get stuck on wet grass. Not to mention resale value...2wd trucks take a huge hit.
[Re: dusturbd340W5]
#1637369
07/01/14 06:43 AM
07/01/14 06:43 AM
Posts: 21,345 Marysville, O-H-I-O
70Cuda383
Marysville, O-H-I-O
I've owned mine for 2 months now. Love it.
06, 5.9, Megacab, 4x4. previous owner lifted the front end via leveling kit, added 12.5x35" tires.
I bought it with 87k miles, right at $30k.
This thing is a tank. with these tires, it rolls right through anything and keeps on going. Mileage seems to be around 16, although the lie-o-meter says 19.5 at times. I did add a smarty jr POD within 2 weeks of owning it because I got a good deal on it. I'm leaving it on level 2 for now, because the guys on the cummins forums say that with a bone stock auto trans, level 2 is safe, level 3 has potential to break the trans. On level 2, it picked up a tad on mileage as long as you keep the RPM below 1800, even when accelerating. mash the go-pedal, and it'll spit out a small cloud of smoke then clear up once the turbo spools, and it pulls smooth and strong all the way to 80 (and would keep on pulling, but I have no need to take a 7,000 lb truck faster than 80)
**Photobucket sucks**
