Even a description would be nice. I think I **may** have the vapor line correctly placed by the vapor separator near the tank. I have it going in back (tank side) of the shock mount and then loops under right near the center of the car under the separator nipple.
My questions are:
- Does the vapor line run right along the rocker with the fuel supply/return lines?
- Do the fuel supply and return share the same double clip and then use S-clips to secure the vapor to one of them? Which one?
- Does the vapor line at any point from the torsion x-member back (besides at the tank) have a separate path than the main/return line?
Any description or pics would be nice. I really want to do this right the first time instead of guessing.
Thanks in advance!!
