Re: High charging voltage [Re: Supercuda] #1635177
06/20/14 11:35 AM
06/20/14 11:35 AM
Eastern Ontario
shaker340 Offline OP
Eastern Ontario
I ran a ground wire from the alternator to the VR. Then measured output of alternator; 15v at brass thread stud, 14v at blu wire plugged in next to brass stud and 6.7v at green wire. Measuring at the battery is now 14v running and 12.9 off. It appears to be poor ground.
2008 Challenger SRT8
1940 Chrysler Royal coupe
Re: High charging voltage [Re: shaker340] #1635178
06/20/14 11:42 AM
06/20/14 11:42 AM
You have way too much voltage drop on the positive side also. Clean those terminals/connections!
