68 727 into 74 e body??? #1634508
06/16/14 04:56 PM
06/16/14 04:56 PM
albany ny
0
05dakota Offline OP
05dakota  Offline OP
albany ny
what needs to be done for the reverse lights to work in the 74 cuda. im building basicly a 70 hp 383 , where can I get a basicly stock 70 hp torque convertor?
Re: 68 727 into 74 e body??? [Re: 05dakota] #1634509
06/16/14 06:33 PM
06/16/14 06:33 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Change the rooster comb on the valve body and use the 69 up switch.
Re: 68 727 into 74 e body??? [Re: 05dakota] #1634510
06/16/14 06:52 PM
06/16/14 06:52 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
If you're real lucky it might have the correct roostercomb, it was introduced in late '68.
Re: 68 727 into 74 e body??? [Re: John_Kunkel] #1634511
06/16/14 07:16 PM
06/16/14 07:16 PM
Earth
Rob C Offline
Rob C  Offline
Earth
What is a rooster comb?
Re: 68 727 into 74 e body??? [Re: Rob C] #1634512
06/16/14 07:46 PM
06/16/14 07:46 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Tech archives are your friend. Rooster comb is the part on the lever with the detents on it.
http://www.moparts.org/Tech/Archive/auto/5.html
Re: 68 727 into 74 e body??? [Re: Rob C] #1634513
06/17/14 12:04 AM
06/17/14 12:04 AM
Harrisburg, Pa.
screamindriver Offline
Harrisburg, Pa.
Re: 68 727 into 74 e body??? [Re: screamindriver] #1634514
06/17/14 11:37 AM
06/17/14 11:37 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Make sure it also has the mounting bosses for the shift linkage bracket if your using a factory floor shifter in the car.
