2004 dodge stratus 3.0 trans problem #1633886
06/15/14 12:53 AM
06/15/14 12:53 AM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
working on a friends car, it starts but when you put it in any gear it does not move, rpms seems to drop a little like it engaged,also when its cold it should be above the fill line which it is, when hot the level drops down a bit 1/2 inch? not as much as in a working trans in other cars which drop about 1 inch down, no codes..fuses seem fine, a/t trans relay good..trying to work on this without all the scanners and such..old school way..looked at flexplate and converter attached..nothing broken there..trans select switch ohmed out ok ..any thoughts???
Re: 2004 dodge stratus 3.0 trans problem [Re: AARCONV] #1633887
06/15/14 06:31 PM
06/15/14 06:31 PM
Missouri U.S.A.
71yelladustr Offline
Missouri U.S.A.
I ASSUME its a 2 dr coupe? If so the it will have a Mitsu trans, not a Chrysler 41TE. I have seen several of the Mitsu trans strip out the splines on the input shaft and/or torque converter causing your problem.
392 gen III hemi on E-85 727 trans Dana 60
10.02@134
Re: 2004 dodge stratus 3.0 trans problem [Re: 71yelladustr] #1633888
06/16/14 01:46 AM
06/16/14 01:46 AM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
yes its a coupe..that happened to my grand national trans...front pump and converter broke...no fluid drop..showed not pumping..was not sure if its common on regular cars too...
Re: 2004 dodge stratus 3.0 trans problem [Re: AARCONV] #1633889
06/16/14 09:19 AM
06/16/14 09:19 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I've never been in the mitsubishi trans but I did have one several years ago that did strip the splines inside the convertor .
It had near zero pump pressure. I pulled it thinking it need a pump, till I looked into the convertor on someone elses advise .
put a gauge on it and ck pump pressures.
I know several people who do transmissions, and no one wants to mess with one of these trans ,,myself included
Re: 2004 dodge stratus 3.0 trans problem [Re: gtx6970] #1633890
06/16/14 09:48 PM
06/16/14 09:48 PM
NEW JERSEY
AARCONV Offline OP
AARCONV  Offline OP
NEW JERSEY
checked all the wiring to and from and all checked out fine, took the trans cooler hose off the radiator side and started the car..no fluid coming out..like you said, bad pump or converter splines or the input shaft...
