Re: 70 6 pack motor
[Re: moon]
#1633733
06/14/14 11:59 PM
06/14/14 11:59 PM
RapidRobert
as you know it's going to have those heavy 6 pack rods. Just consider this a BTT for ya
Re: 70 6 pack motor
[Re: moon]
#1633734
06/15/14 12:07 AM
06/15/14 12:07 AM
Posts: 8,828 Houston, Tx
hemi68charger
Houston, Tx
Torque convertor with weights or no weights? and if yes on weight, how much?
Yes on the weights since it was an externally balanced motor ( '70 & '71 4bb and 6bbl ) had the same thing...
Now, I haven't found anything on the exact weight and placement, sorry. I'll keep looking....
TroyHouston Mopar Connection Club'69 Charger Daytona 440 - auto - 4.10 Dana (now with 426 hemi) '69 Charger 500 440 - 4speed - 3.54 Dana '70 Road Runner 383 - 4speed - a/c (now with 440)
Re: 70 6 pack motor
[Re: moon]
#1633735
06/17/14 05:12 PM
06/17/14 05:12 PM
Posts: 13,375 Marion, South Carolina [><]
an8sec70cuda
Get the B&M flexplate w/ the notch cut out for the external balanced motors and you don't need a weighted converter. http://chucker54.stores.yahoo.net/bm1.htmlBMM-10238 is for the forged crank engines that are externally balanced. B&M makes 2 that look similar. BMM-10237 is for the later cast crank externally balanced engines.
Re: 70 6 pack motor
[Re: an8sec70cuda]
#1633736
06/17/14 05:55 PM
06/17/14 05:55 PM
Posts: 15,134 Kelowna, B.C. Canada
DPelletier
FYI, the much-maligned (and mis-labeled) "six pack" rods aren't THAT much heavier than the old '69 LY's. With some decent pistons, my '70 440-6 is internally balanced using the "six pack" rods and has less reciprocating mass than the stock '69 LY rod engine. Dave
1970 Super Bee 440 Six Pack
1974 'Cuda
2008 Ram 3500 Diesel
2006 Ram 3500 Diesel
2004.5 Ram 2500 Diesel
2003 Ram 3500 Diesel
2006 Durango Limited
[url] http://1970superbee.piczo.com [/url]
Re: 70 6 pack motor
[Re: DPelletier]
#1633737
06/18/14 10:17 AM
06/18/14 10:17 AM
Posts: 721 Seminole County FL to Plymouth...
Barry70GTX
Did you keep the stock large damper on it?
NMCA NSS 67 Coronet
Re: 70 6 pack motor
[Re: DPelletier]
#1633738
06/18/14 10:28 AM
06/18/14 10:28 AM
an8sec70cuda
My '71 HP 440 w/ six pack rods is currently internally balanced...had it done when I freshened it up. Has a set of ROSS flattops in it. No more dealing w/ scalloped flexplates and weighted balancers.
I took it as the OP is dealing w/ a complete motor and is not in the rebuilding stage.
Re: 70 6 pack motor
[Re: Barry70GTX]
#1633740
06/18/14 01:26 PM
06/18/14 01:26 PM
DPelletier
No.
1974 'Cuda
