X pipe. mandrel bends. your choice of muffs up front. glasspacks alongside the leaf springs (pick ones that do not neck down where the end nipples are welded to the main case). Use the longest ones that will fit.
www.classicindustries.com has a good selection. I've heard the gasses contract as they cool rearward & you can get by with smaller tailpipes, that would not be my choice. The best would be some manual cable or vac operated cutouts. Normally run thru some restricted (quieter) muffs then cut outs when you need it
. I mean at that point you dont care how loud it is till the race is over & that's only 6 seconds or so & the rest of the time it's reasonably quiet. They'll never know what hit em
