electrical terminal and harness clips #1631361
06/10/14 12:15 AM
06/10/14 12:15 AM
Houston, Tx
hemi68charger Offline OP
Houston, Tx
Hey gang..
I looked and search but couldn't find the following:
1. 6-connector ( female end ) for the headlamp harness in the picture
2. the little clips that plug into the inner fender panel behind the battery that holds the headlamp harness in place. The clip is attached to the fender and then tape wrapped around it and the harness.
PS: I know I know... the paint is messed up a little by the battery. But yeah, she's a driver......
Troy
Houston Mopar Connection Club
Re: electrical terminal and harness clips [Re: hemi68charger] #1631362
06/10/14 06:11 PM
06/10/14 06:11 PM
NC
1970A66 Offline
1970A66  Offline
NC
I can't guarantee these are identical but for the price it may be worth a shot. I just ordered 8 pin connectors (in transit) for a Challenger tail light harness connector cause they look stock.
http://pcsconnectors.com/6-cavity-connectors.aspx
They take the stock type Packard 56 terminals and you can get them from the same guys. Since 100% correct isn't mandatory, buy the male and female halves along with any needed terminals.
Is this the other thing you are after?:
http://pcsconnectors.com/12160857.aspx
Re: electrical terminal and harness clips [Re: 1970A66] #1631363
06/10/14 07:26 PM
06/10/14 07:26 PM
Houston, Tx
Houston, Tx
These are similar, but I was looking for something factory. I know there has to be a source out there since M&H makes OEM harnesses. They have to get their parts from somewhere...
Thanks for the links though, I can use them for other items for sure.
Troy
