Tilt Column For 77 Pickup #1628447
06/04/14 03:15 AM
06/04/14 03:15 AM
Keizer, Oregon U.S.A.
E
elmor353 Offline OP
elmor353  Offline OP
E
I would like to swap my current steering column for a tilt unit. What years and vehicles would bolt in? It's a 77 D100 auto.
Re: Tilt Column For 77 Pickup [Re: elmor353] #1628448
06/04/14 03:30 AM
06/04/14 03:30 AM
chicagoland,usa
buildanother Offline
chicagoland,usa
Through 1980 should go in there easily I imagine. You may have to get matching wiring for dash harness too.
Re: Tilt Column For 77 Pickup [Re: buildanother] #1628449
06/04/14 03:55 AM
06/04/14 03:55 AM
Kent, Wa
340SHORTY Offline
Truck Nut
340SHORTY  Offline
Truck Nut
Kent, Wa
IIRC untill 81 there wasnt a tilt option in the trucks.. .. The wiring is different also..
I am truckless..
Re: Tilt Column For 77 Pickup [Re: 340SHORTY] #1628450
06/04/14 11:11 AM
06/04/14 11:11 AM
chicagoland,usa
chicagoland,usa
There were tilts in 79 and 80 I'm positive.
Re: Tilt Column For 77 Pickup [Re: buildanother] #1628451
06/04/14 11:29 AM
06/04/14 11:29 AM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
A 78 only tilt column is the only column that will fit your truck correctly
78 is the first year for tilt
79-80 has different mounting under the dash than 78 down trucks
Re: Tilt Column For 77 Pickup [Re: BulletBob] #1628452
06/04/14 09:43 PM
06/04/14 09:43 PM
Back home in PA
BulletBob Offline
BulletBob  Offline
Back home in PA
Here's a pic of the two different columns with the 78 on the left (one year only) & the 79-80 on the right
It's not hard to figure out why the column mounting changed
That's the 78 on the bottom
