How do you seal your tranny dipstick tube?
#162833
12/05/08 09:41 PM
12/05/08 09:41 PM
Posts: 12,192 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
My 727 dipstick tube leaks all the time. I think this has been covered here before, but what is the best way to seal the tube to the case? I have the engine out right now, so access is good. Thanks!
Master, again and still
Re: How do you seal your tranny dipstick tube?
[Re: RapidRobert]
#162840
12/05/08 11:09 PM
12/05/08 11:09 PM
Posts: 4,616 Kissimmee Fl.
dusturbd340W5
Kissimmee Fl.
I would be looking at the tube real close to see if it is bent or cracked at the groove also check and make sure that the tube is going in the case deep enough. We install tubes at work on a daily basis with NO sealer and rarely ever have one leak if all is in good shape
70 duster full chassis super pro 416 CNC Indybrock heads 727 w/brake
best so far 1.212 60 6.219 in 1/8 at 110.88 9.768 at 137.81 1/4
[Re: dusturbd340W5]
#162844
12/05/08 11:36 PM
12/05/08 11:36 PM
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Sounds like I need to spend some quality time with my tube and O-ring. Thank you!
[Re: DaveRS23]
#162848
12/11/08 01:11 PM
12/11/08 01:11 PM
Posts: 2,930 Odessa, Tx.
cudarex
Odessa, Tx.
The aftermarket locking dipsticks with a hefty seal (non o-ring) are pretty nice.
I must have missed that. Who offers those?
Cope Racing has them.
[Re: BELVEDERE67]
#162850
12/11/08 01:26 PM
12/11/08 01:26 PM
RapidRobert
is the O ring square or a regular round one. A new round one(not from a trans shop though) leaked until I pulled the pan in my post but I remember thinking that the OD should have been larger.
