1968 Plymouth Fury Oil Pan Removal Engine in Car #162804
12/05/08 08:27 PM
12/05/08 08:27 PM
fury4speed Offline OP
Do you have to jack up the Engine a bit or does the oil pan come off without lifting the Engine , Fury "C" Body RB Engine stock K member , thanks.
Re: 1968 Plymouth Fury Oil Pan Removal Engine in Car [Re: fury4speed] #162805
12/05/08 09:59 PM
12/05/08 09:59 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
It's a pita job, engine does get jacked up a bit. Gotta clear the pickup while dodging all the external obstacles. If your pan isn't baffled it'll be a bit easier.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
